Hi all,
I bought an unlocked S3 mini from Amazon UK in December, and since then have been using it on the O2 network without problems. I arrived in Italy last week and decided to buy a local SIM card from the TIM network here to avoid roaming charges.
Everything works fine - calls, texts, data - except that my battery now drains at a crazy rate, from 100% to empty in about five hours, and at around 1% a minute if I'm actually using it. I was on O2 roaming for a couple of days when I first arrived, but I'm not sure whether I had the same problem then as data was turned off.
A very 'helpful' 'friend' told me that the phone was searching for a network in the UK, that there was no hope of fixing it and that I should get an iPhone instead. Is he right, at least about the phone searching for a UK network? I can't understand why that would be when all the settings are TIM. Would a factory reset help?
Thanks in advance for any suggestions!
