Results 1 to 3 of 3
    Default WEIRD Problem, Please help
    First, routed wicked sensation v.05.....I was playing with one of my contacts. I had it set to dial then pause dial extension pause and dial password. set up with ( symbol. All I wanted to do is change this to (,) so I would not have to manually press the (wait) button.
    So my issues begin!
    My phone will now not accept any extensions at all. Maually or automaticlly. I have it set up so there is a tone with the extension so I can here it enter, but on the other side a default eventually comes on and basiclly says (still waiting for your entry) I tried different numbers in case it is the party I am calling and it is not. I looked through everythink I could think of on my phone to reset. Even reloaded wicked sensation incase something screwy happened there. I now can not dial any extensions on my phone. What the hell did I go and Do????
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: WEIRD Problem, Please help
    Quote Originally Posted by macmov View Post
    So my issues begin!
    Have you tried a reboot? If that doesn't work reflash the ROM and you should be back to normal as if the mod didn't happen. Those edited files will be replaced with those of the ROM.
    hats whats weird. I did a complete wipe and downloaded an old recovery and it is still not working. I can dial a number then it seems to not recognize any buttons after the call connects. I can not enter extensions. It will manually enter but it will not recognize the entry.
  1. M8 GPS signal problems (signal breakups)
    By svencux in forum HTC One M8
    Last Post: 08-01-2014, 03:46 PM
  2. chrome problem
    By gjbrns in forum Google Nexus 4
    Last Post: 05-28-2014, 10:15 PM
  3. wifi problem
    By thanas77 in forum Samsung Galaxy Note 3
    Last Post: 05-26-2014, 07:14 AM
  4. Samsung Galaxy added extra weird task bar? please help me remove it! anyone?!
    By kateashleytejada in forum Sprint Samsung Galaxy Note 3
    Last Post: 05-26-2014, 03:28 AM
  5. Really really need help.
    By Omario23145 in forum HTC One Mini
    Last Post: 05-26-2014, 01:40 AM
