DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Results 1 to 19 of 19
Like Tree3Likes
  • 1 Post By savadepa
  • 1 Post By Lanhoj
    savadepa's Avatar
    Posts
    Global Posts
    159 Global Posts
    Default S3 LED notifications while screen is ON
    I have Light Flow installed on my S3, but the LED notifications only work while the screen is off. Is there any way to have my LED blink when the screen is on?
  2. #2
    Skunkape60's Avatar
    Retired Ambassador
    Posts
    Default
    I've never used light flow but there is an entire thread on xda where they found that light flow is causing the gs3 not to sleep properly and causing battery drain. After removing it the phone starts sleeping again.
    _______________
    Just Flash It !!!
    Thanked by:
  3. #3
    Mikest's Avatar
    Posts
    Global Posts
    765 Global Posts
    Default Re: S3 LED notifications while screen is ON
    every demo of lightflow I've seen on youtube you have to turn the screen off to see the LED colors. Not helpful but I thought Id throw in my two cents.
  4. #4
    Default
    Why would you need it to work while the screen is on?
    Sent from my SAMSUNG-SGH-I727 using Android Central Forums
  5. #5
    i guess he wants it there until he actually clicks on the notification.
    savadepa's Avatar
    Posts
    Global Posts
    159 Global Posts
    yes. Whatsapp only notifies me in the notification bar for a second or so, so it's easy to miss. Also, I want to know if I received new messages when I'm watching a video or playing a game.
    wickets likes this.
  7. #7
    How bout that XDA thread link??
    edit: okay, easily found the , but only one person has had battery drain issues. No battery problem, but other possible problems with text to speech accessibility settings.
  8. #8
    JNM
    JNM is offline
    JNM's Avatar
    Posts
    Global Posts
    302 Global Posts
    I use Light Flow on my Galaxy Nexus and it only blinks the LED when the screen is off. Email the developer and see if there is any way to make it work with the screen on on the Galaxy S3.
  9. #9
    Default
    Quote Originally Posted by JNM View Post
    The led not flashing while the screen is on was something built into the android os in 2.2. Cause my notifications in 2.1 on my og droid would flash when the screen was on but it changed to not flashing while the screen was on after it received 2.2
  10. #10
    I asked the developer this when I got my nexus last year and he said, if i recall correctly, it has to do with the os itself or the phone. He has tried to do it but it just can't be done...at least on the gnex.
  11. #11
    I know this thread is for LED, but why don't you give NoLED a try? It uses icons on your screen to show notifications (way cooler than LED blinking). The app was developed with phones without an LED in mind (Hello, Galaxy S and Galaxy S2), and since they've been OLED screens, showing icons with a black background doesn't actually drain your battery so drastically; I'm not sure if a bright LED will, though... Anyway, even if my phone had an LED I'd still go with NoLED IMHO...
  12. #12
    I love LightFlow but I also combine it with a whack of other Notification Apps:
    NotifierPro Plus - WP7 style Notifications
    StatusBar+ - Custom Status Bar without needing to be rooted
    Smart Statusbar+ - Being able to access the Status Bar while within fullscreen Apps
    Missed It! - Displays Notifications within a Widget (I keep it on WidgetLocker & Nova Launcher Prime)
    TeslaUnread - Put an iOS style "Badge" in the corner for SMS, GMail, Missed called & Voicemail (requires either WidgetLocker or Nova Launcher Prime)
    Yeah, combined with LightFlow that's about 20$ worth of Apps that are pretty much only for monitoring my Notifications, but I really can't live without any one of them & they all serve their own important purpose. So, if you're as serious as I am about your Notifications, I highly recommend you look into some of those as well.
    PS: I also disable within each of my Apps their specific "pop-up" Notifications like in GO SMS Pro, textPlus Gold, etc... since I don't like how they all look different & overlap.
    Nashstruck likes this.
  13. #13
    Wicell's Avatar
    Posts
    ROM
    MIJJzGoodnessFD02/ Rouge
    Quote Originally Posted by savadepa View Post
    I assume by watching a video or playing a game you man on your phone. There is a setting built in to WhatsApp that gives you ask iOS style pop up notification on screen that doesn't go away until you press "cancel/clear" or "view." This is very helpful for me, just thought I've let you know in case you haven't tried it.
    Quote Originally Posted by Spook81 View Post
    I hate to brag, but Sprint's S2 has a notification light.
  14. #14
    E_man's Avatar
    Posts
    ROM
    Rooted AOSP JB on all
    NoLED demolished my battery. Contrary to popular belief, black on an OLED is not off. It's just really close. You can even see this yourself in a dark room. YMMV.
    As for an LED, the battery drain for that is minimal. We're talking 10-15 milliwatts.
  15. #15
    Yes sadly it seems to be something coded into the android OS.
    I did look into the source code a while ago and saw where this happens.
    The only way I know around this is by using some customs roms that add the option in, then lightflow should work with it.
    I've not looked specifically at the S3 code, but I would guess it's just using the standard android code for this (as behaviour is pretty much the same as the galaxy nexus)
    I'm testing lightflow on an S3 for the next release to make sure I can get as much lookin ok as I can before release.
  16. #16
    Default
    I' m just wondering why light flow on GNex? My red, blue, yellow, green and white notification lights work fine. What am I missing out of not having light flow? :o
    Sent from Alexis Nexus
  17. #17
    I need the LED light notification capability myself while the screen is on, because I want my cell phone to operate for my home office exactly like a regular office phone would: The screen is always on in a holder (set to always on when charging, which is all the time), is always set to the phone screen, is connected to a nice Bluetooth speakerphone, and where the LED should blink red when a call has been missed and there is a voice message waiting. The only part I cannot get to happen is the last part. Is that too much to ask?
  18. #18
    LF will do this on a rooted S3, using the S3 root mode checkbox. But I've found with that checked, the alerts themselves sometime don't stay on as long as I've chosen.
    Do you really need the screen on when in the charger? It doesn't seem to me staring at the phone screen is particularly useful, since it will turn on anyway if someone calls you.
    PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
    If I've helped you, please press the Thanks button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
  19. #19
    The reason I keep the screen on is that even with the SoundAbout app, I haven't been able to get it to automatically connect to my BT speakerphone for an incoming call (Jabra speak510, answer by hitting pick up button on speaker, not phone itself) when the screen is off, it only works when the screen is on so far with all my tweaking of the answering settings of the phone and SoundAbout options.
