1. razortaz18's Avatar
    So I've got a Galaxy Nexus now, with the extended battery. I'm wondering if anyone knows if I'll be able to use that battery as a spare for the S III?
    06-12-2012 08:33 PM
  2. RifterAD's Avatar
    Looking at the reviews that have shown pictures of the battery, it looks like the batteries have a similar rating (3.7v vs 3.8v and 7.77Wh vs 7.98Wh). The pins are on the right side on both phones (when looking at the rear), but the pins are on the top in our GNex phones, but on the bottom of the SIII. Despite that difference, the battery should fit (assuming the batteries are the same size), but you'd have to flip it which means that the NFC antenna would be on the other side and may not work well (if at all).
    I plan on testing this out with my GNex extended battery once I get the SIII...here's to hoping.
    06-12-2012 11:09 PM
  3. kath00's Avatar
    Same situation here. Please let me know what you find.
    06-13-2012 04:05 PM
  4. Rukus911's Avatar
    Will not WORK! I have both phones, and the GNex extended battery is thicker and shorter and will Not Work! Hope this helps.
    razortaz18 and NotJustAPhone like this.
    06-25-2012 12:32 PM
  5. MrSlippery519's Avatar
    Just to clarify, this response is 100% correct the batteries are not interchangeable.
    06-25-2012 01:45 PM
  6. RifterAD's Avatar
    I can also now confirm that the batteries are not the same size. As the other's said, the GNex battery is shorter (by a lot), and much thicker.
    07-08-2012 06:07 PM
