Results 1 to 21 of 21
    JayGoat's Avatar
    Posts
    Global Posts
    125 Global Posts
    Default Official wireless charging battery cover to be thicker?
    Now this is just pure speculation right now, but do you think the battery cover coming out sometime in September to enable wireless charging is going to be thicker then the current battery cover?
    Personally, I think it will have to be thicker to house the coil, connection pins and microchip. The reason I ask though is it seems like they are going to make us choose if we want wireless charging or a case. I'm sure some manufacturers will come out with cases to fit the thicker battery door but I'm also sure some won't.
    Again, pure speculation, just wanted to see what others thought.
  2. #2
    Default
    My guess would be yes. But then againg they could pull it off
    Sent from my T-Mobile G2 using Android Central Forums
    JayGoat's Avatar
    Posts
    Global Posts
    125 Global Posts
    Default Re: Official wireless charging battery cover to be thicker?
    Well here's that these coils can be made a little thinner than the one's in the Palm Pre. So maybe Samsung can pull this off.
  4. #4
    No it isn't thicker.
  5. #5
    firetruck41's Avatar
    Posts
    ROM
    Stock
    Default
    Quote Originally Posted by Nashstruck View Post
    Curious how you are able to give such a definitive answer? I am certainly hoping the same.
    Sent from my DROIDX using Android Central Forums
  6. #6
    Quote Originally Posted by JayGoat View Post
    It seems to be a bit thicker i have one. but not by much but i dont have any cases to se if it makes a difference on fitting. but my guess is some cases might not fit. i just put them side by side and yes its defently thicker
    Thanked by:
  7. #7
    Posts
    ROM
    Stock
    Default
    Quote Originally Posted by phullofphil View Post
    How did you get a wireless charging back cover? Would love to see some pics of both sides of it. Do you have the wireless charging pad as well?
    Sent from my SCH-I535 using Android Central Forums
  8. #8
    Default
    Someone made one using the stock battery cover I think. So it is possible, but it will probably be a few mm thicker.
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
  9. #9
    i hope not!
    converted
    iPhone 4 ---> Galaxy S3
    hopefully.. Galaxy S3 ---> Note 2
  10. #10
    Default
    Available now from Verizon Corporate Store for $39.00. Stock Verizon Charging Matt $49.00 or $20.00 from Ebay. The backplate is slightly thicker and much more firm. Sorry for the rushed pics, just wanted to get them online. The color of the back plate is pebble blue, however the color is slightly richer than the stock backplate. Cases are going to be a problem. My kickstand case from Verizon will not fit at all. The Cruiser case in the photo is a gel slip-on, but the slight bulge makes the edges slip-off the sides with not much effort.
    Attached Thumbnails Attached Thumbnails Official wireless charging battery cover to be thicker?-uploadfromtaptalk1343972889755.jpg   Official wireless charging battery cover to be thicker?-uploadfromtaptalk1343972909122.jpg   Official wireless charging battery cover to be thicker?-uploadfromtaptalk1343972931166.jpg   Official wireless charging battery cover to be thicker?-uploadfromtaptalk1343972979949.jpg
    Thanked by 2:
  11. #11
    Posts
    ROM
    Stock
    So what is the extra piece/contacts (the part over where the SIM and SD cards are) for, that are Verizon specific? Could it be related to NFC? I wonder if there will be another Samsung battery cover that omits that part, for all of the other phone variants?
  12. #12
    Default
    The NFC is located closer to the camera. The contacts that you are referring to are Verizon exclusive and is supposed to be compatable with their accessories.
  13. #13
    Some more pics here.
    I wish someone made a back that would work with the touchstone.
  14. #14
    Quote Originally Posted by mc_gusto View Post
    so you are certain it will NOT work with the touchstone?
  15. #15
    Maybe I'm missing something but what is the point of the wireless charging pad? My "assumption" is that the wireless charging pad has to be plugged in somewhere. If that's true then why not just plug in the phone charger? I'm guessing the wireless charger is good so if you put the phone down somewhere it's charging and then you can pick it up and walk around with it (then putting it back on the charger when done walking)?
  16. #16
    Posts
    ROM
    Stock
    Quote Originally Posted by ansextra View Post
    I think the pluses are convenience, and not plugging/unplugging from the micro-usb port 20 times a day, thus reducing "wear and tear" on the recptacle. I know its supposed to last for thousands or tens of thousands of plugging/unplugging cycles, but I just cant help but think I am wearing out the connector when I do so. But convenience is also a big seller for me, just set it down as I walk by, and not give it a second thought. I think I will wait until there is a more economical version/alternative though.
  17. #17
    I bought the verizon branded wireless charger and battery cover, today. The cover is definitely slightly thicker. After installing it, my hard case will not fit, at all, and my TPU case bulges around the middle of the phone.
    As an FYI, it does not work with a Palm Touchstone, either. The Palm battery covers had a magnet in them that would hold the phone steady on the Touchstone. The Samsung battery cover is not magnetic, at all.
    Thanked by:
  18. #18
    Default
    So it doesn't hold on for a charge? What if you hold it steady over the touchstone? I does it charge? It's really a $6 dollar solution to place magnets there.
    Thanks!
    Sent from my Samsung Galaxy S3 using Tapatalk2
  19. #19
    Quote Originally Posted by johnj2803 View Post
    I did hold the GS3 up against the Touchstone and varied the contact area between the Touchstone and the phone to see if I could pick up a charge, but nothing worked.
  20. #20
    Default
    Quote Originally Posted by undeniablyd View Post
    The Verizon version is their version of powermat from my understanding. It is different from what Samsung described as wireless charging as with Verizon'a kit, there must be contact between the phone and pad. Whereas Sammy's description is you can pick up the phone and be within a few inches or so from the mat and use the phone and it will still continue to charge.
    - Gordon
    - BlackBerry Bold 9900 (Black)
    - [SOLD] HTC Glacier (White)
  21. #21
    Default
    From what I've read for the S3 the battery holds the NFC chip. Whereas compared to my Bold 9900 there are contacts which touch the backdoor and the backdoor acts as an extended NFC chip.
    - Gordon
