- 06-19-2012, 09:41 AM
Thread Author #1
Any way to "auto-sleep" when placed in holster/case?
As I've previously mentioned, I'm waiting for my S3 to arrive,making the move from BlackBerry after almost 7 years. One of the really nice (I'm sure patented) features all BlackBerry's have had for years is the reed switch to put them automatically in "sleep" mode whenever you slide them into a case designed for BlackBerry - which means a magnet embedded in the case to activate the sleep switch.
The profile settings allow you to set different responses for "in holster" vs. out, so mine is set to automatically go into audio-muted, vibrate-only for everything except phone calls when placed into the holster.
Anything like this in the Android world, and specifically for the S3 I'll soon have? - 06-19-2012, 09:52 AM #2
- 06-19-2012, 09:52 AM #3
Re: Any way to "auto-sleep" when placed in holster/case?
Couldn't use get an NFC tag from tagstand.com and set it to do that?
- 06-19-2012, 09:53 AM #4
- 06-19-2012, 10:06 AM
Thread Author #5
Thanks - already was looking at those, definitely interesting. The issue I see is - easy enough to put it INTO sleep mode that way, by sticking one of those tags inside the case. NOT so easy getting it OUT of sleep mode though, wouldn't you need another tag somewhere (not in the holster) to put it close to for that? And just where are you going to keep that second tag to always have it handy?
Yes, essentially when the BlackBerry is put into a holster, it goes to a different profile. The trick is how to get the S3 to KNOW its been put into the holster so that it will switch to that profile? As for the NFC tags, see above - seems like half an answer, but not the whole answer. - 06-19-2012, 10:27 AM #6
- 06-19-2012, 10:32 AM #7
Could you put 2 NFC tags in the holster, 1 at the bottom and 1 at the top. So upon inserting into the holster, the phone passes over both NFC tags, reads "wake up" tag, reads the "sleep" tag, and then is resting on the "sleep" tag in the holster. Upon removing from holster, it passes over the "wake up" tag only.
Thoughts? - 06-19-2012, 10:34 AM
Thread Author #8
I'll have to play with it once it arrives, hope it ends up being that simple! My BB Torch goes into a mode in the holster where phone calls ring as normal, but every other event (email, SMS, IM, etc) only uses vibration. That sounds like a profile rather than just "sleep." If you simply put it to sleep, will phone calls still ring while everything else is vibrate-only?
- 06-19-2012, 10:36 AM
Thread Author #9
- 06-19-2012, 10:38 AM #10Thanked by:
- 06-19-2012, 10:41 AM #11
- 06-19-2012, 10:50 AM
Thread Author #12
- 06-19-2012, 10:55 AM #13
Also, I'm not sure why this is unnecessary in the first place. Why not just tap the power button which turns off the screen? I do this and test it with my G-Nex with CPU Spy app and it automatically shuts off one of the CPU cores entirely and puts the other core into "deep sleep" mode. For funtionality issues I suggest you look at the app tasker and look at some of the truly cool things people have done with this. I think XDA had a huge thread where people post their profile files for examples.
- 06-19-2012, 11:07 AM
Thread Author #14
Issue is, I want to do more than just turn the screen off. Want to change the notifications on some, but not all events from audio to vibrate-only and back again. Maybe you can do it with the app tasker you mention, but again it seems you have to have a way to kick off the task? I am new to Android though, so will run over to xda and look.
- 06-19-2012, 12:02 PM #15
I used to have Blackberries and understand how useful this feature is in the Blackberry. Basically there was a magnet in the case... and whenever the phone was around this magnet (in a specific location) it would go into "holster mode".
I like the idea of using NFC tags to put it into "holster mode"... just not sure how well it would work when taking the phone out of the holster? If the phone can quickly register an NFC tag... then maybe putting two tags in the case would work. But if it's not quick enough... maybe you'd need to use a tag to put it in the holster and push a button to change the mode when you take it out of the holster? - 06-19-2012, 12:17 PM
Thread Author #16
- 06-19-2012, 12:21 PM #17
Reply
