Page 1 of 3 123 LastLast
Results 1 to 25 of 55
Like Tree6Likes
    Default SGS3 won't connect to my Mac... Help please!
    I've tried everything, but am unable to get my Mac to see my brand spanking new Galaxy S3. I can't get it to show in the finder, I can't get it to show in Kies, and several other methods have failed as well.
    Not sure what to do next.
    Any help would be greatly appreciated. I can't get any music to the device.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  2. Thread Author  Thread Author    #2
    Default
    By the way... The other two methods were Easy Phone Sync (doesn't see the device) and iSyncr (which won't even run.)
  3. #3
    Default Re: SGS3 won't connect to my Mac... Help please!
    [CENTER][URL="https://plus.google.com/u/0/+KPSmith/posts"]Follow me on Google +
  4. #4
    Great info KSmithInNY,
    I was just going to suggest android file transfer as well.
    Thanks for the help. I get "No Android device found" with Android File Transfer.
    I've tried turning off the phone, and turning it back on. The GS3 says it is connected as a Media Device, and charges fine....but my Mac just doesn't see it still.
  6. #6
    I have to use samsung kies.
  7. #7
    20blks's Avatar
    Posts
    Global Posts
    774 Global Posts
    Quote Originally Posted by KSmithInNY View Post
    Thanks, I was looking for this all day. Is it safe to assume that there's no way to move apps to sd on the GS3?
  8. Thread Author  Thread Author    #8
    Default
    Quote Originally Posted by 20blks View Post
    Everything I read said that apps on sd card aren't possible. I been reading a lot lately just trying to get things running.
    Sent from my Samsung Galaxy S3 using Tapatalk 2.
  9. #9
    MaTiCeK's Avatar
    Posts
    Global Posts
    42 Global Posts
    Default
    In order to make Androud Phone Transfer app work on my MBP13 I have to select PTP (photo transfer mode) on my international SGS3.
    Sent from my GT-I9300 using Tapatalk 2
    MBSMD likes this.
  10. #10
    Super_Mario's Avatar
    Banned
    Posts
    Global Posts
    3,079 Global Posts
    With all the lawsuits between Samsung and Apple, I'm not surprised it doesn't work. Even their technology hates each other.
    lololovestech and darthnix like this.
  11. #11
    Default
    I followed the above information and it worked just fine.
    Sent from my Xoom using Tapatalk
  12. Thread Author  Thread Author    #12
    Thanks for all the tips. Here's the latest. Nothing seemed to work, so I did a re-install of Lion from the recovery partition. Not a clean install...just over the top of my existing data.
    Result:
    Kies actually recognized my device. Once. It was locked, and it told me to unlock. After that, I couldn't get it to connect. It recognizes something is there because it tries to connect for a very long time and seems to never finish "Connecting".
    When I switch to PTP, Kies doesn't see it to even try and connect anymore...but OSX pops up a finder window to let me browse the phone and card. Yay! (Android File Transfer seems to be working after the refresh.)
    I really wanted to Sync my iTunes library and playlists, rather than just dragging and dropping. so I tried iSyncr again (which I bought in the middle of all this). It doesn't recognize the device in PTP mode...but it does now in the MTP mode (once I killed Android File Transfer). Right now it's syncing my iTunes library to my 64GB MicroSD card...so I am miles ahead of where I was earlier!
    Thanks again for all of the assistance. I remember when I first went to iPhone (from the HTC Incredible at the time) and I remember now that a huge part of the decision was based on how "plug and play easy" the experience was. Of course...outside of that...I just got bored with iOS...so here I am again. ; -)
    dmmarck likes this.
  13. #13
    dmmarck's Avatar
    Retired Moderator
    Posts
    Global Posts
    10,930 Global Posts
    ROM
    What do you think?
    For those who haven't used it extensively, Android File Transfer is riddled with craziness. I suggest transferring stuff bit by bit--no big folders. It likes to freeze up at the most inconvenient times, usually when transferring a gig or more at once. I also have had better success with the USB port closest to my MBP's screen; why? Who knows. I just know to always plug into that one.
    Further, for some reason, if USB debugging is "checked" in Developer Options some files refuse to show up in AFT upon reboot. I have to uncheck that then reboot for the full array to show up. Why? Again, I have no idea. I just know that the app is sort of...crappy.
  14. Thread Author  Thread Author    #14
    Default
    "official" word from Samsung, regarding Kies, gs3, and osx:
    "Thank you for your inquiry about your Samsung Galaxy S III (AT&T)(SGH-I747) and we understand that the phone can't recognize on your Mac computer.
    We apologize for any inconvenience this may have caused you. Currently, the phone is not compatible to Samsung Kies software that is installed on a Mac computer. We will forward your feedback to the appropriate parties for further review and consideration."
    Not a smart move if you're trying to get some of the iPhone market share with the S3, which is the one phone that has a shot at it.
  15. #15
    mmunsch's Avatar
    Posts
    Global Posts
    20 Global Posts
    I too was having this issue with an AT&T Galaxy S3 connecting to a MacBookPro. I downloaded Android File Transfer and everything, and it still wouldn't recognize the phone in MTP. However, after switching from MTP to PTP, AFT sees the phone right away and I can transfer files and photos. So not the easiest or most user friendly way to connect, but it's better than using Airdroid or a similar program to transfer. And on a side note, once connected it transfers files FAST, a big improvement over my retired Captive (original Galaxy S).
  16. Thread Author  Thread Author    #16
    Quote Originally Posted by mmunsch View Post
    Thanks. I found the same to be true. My only real desire for Kies connectivity is for firmware updates, which supposedly is the only way to update. With Jelly Bean surely coming, I want to make sure I have things working. As far as music...Syncr worked great with AFT.
  17. #17
    Guys after the new update for SGS3 by Samsung, i can no longer connect to Android File Transfer. Any one knows a solution ?
  18. #18
    broopa's Avatar
    Posts
    Global Posts
    23 Global Posts
    Default
    I was having this problem to and noticed a fix somewhere that disabled kies over wifi. Since the command works i went ahesd and deleted kies over wifi from the program direcTory. On the version of kies that was available for download last Friday. The update that keeps coming through breaks this quick fix.
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
  19. #19
    hi,
    can you help me with my MAC usb connection? i cannot also access my galaxy s3 when i connect it to my white macbook..and by any chance you can tell me what is the meaning of i icon on the left topmost part of my screen?
    Thanks.
    Attached Thumbnails Attached Thumbnails SGS3 won't connect to my Mac... Help please!-screenshot_2012-08-14-19-30-47.jpg
  20. #20
    I use Airdroid work very well with Mac. Also use Droid NAS for file transfer if you like to use the Mac Finder / file management etc..
    hope that help
  21. #21
    MBSMD's Avatar
    Posts
    Global Posts
    481 Global Posts
    Quote Originally Posted by android newbie_28 View Post
    hi,
    Thanks.
    For Mac connection, see the posts above. Basically, download Android File Transfer for Mac, connect your phone, and switch it to PTP mode.
    The icon is the No Notification symbol. See the Notification button in your toggle bar? It's off. Turn it back on. You might have hit it by accident or pressed it without knowing what it does.
    Nexus 5 • Nexus 7 • Surface Pro 3
  22. #22
    rcook55's Avatar
    Posts
    ROM
    Back to Stock TW
    Just got my SG3 today and I also have several Macs. Some things I've noticed that weren't mentioned so far. iSyncr won't work if Kies is installed so if you want to use iSyncr you need to remove Kies. Also it was odd but you have to make sure that when connecting to Kies that the phone is on and unlocked, if it goes to sleep Kies won't see it, this isn't a problem once the transfer starts but you need to keep the phone up until Kies sees it.
    I've found that iSyncr is pretty damn cool. Made a 25Gb playlist in iTunes and am in the process of syncing it now. I also notices that Kies said I had a total of 2.66Gb of music but there's a bug in that I have 126.6Gb of music, Kies apparently can't see past 3 digits of music!
  23. #23
    Hi there, Android 3 and Android 4 devices simply cannot be detected by your Mac as it was possible with earlier OS's when you connected device via USB.
    In such case you should use third-party apps to mount and sync Andoid with mac. One of such apps is SyncMate - it syncs Android with mac and mounts your device as Mac disk.
    SyncMate has free edition, you can test it prior purchasing and decide if this app worth your attention.
  24. #24
    Hey
    I have the same problem as you, but my phone is the HTC one S, so i don't know if what you did works for the phone too. Btw i have no idea how to switch to the PTP mode. Can you help please?
  25. #25
    sumsung galaxy3 is unable connected to macbook....what is the problem?
