Results 1 to 5 of 5
- 06-23-2012, 11:26 PM
Thread Author #1
weather location not updating
anybody else having problem with this? i've tried setting > enable current location .> auto-scrolling > auto refresh, but it seems like it's stuck on a city 60 miles away. i've tried clearing the cache/force stop as well.. any advice?
thanks in advance - 06-24-2012, 01:06 AM #2
I've had this too. What you have to do is go to the settings screen in the app-widget and disable, then reable, the current location. If you get sick of that, disable the current location feature, and add the two or three towns you are normally in. This lets you scroll up and down on the widget to see different temperatures.
Sent from my GT-I9300 using Android Central Forums - 06-24-2012, 06:25 AM
Thread Author #3
Re: weather location not updating
thx, dreissig! that's exactly how i got mine set up right now, lol. i remember my old htc evo had the same problem when i got it two years ago... i'm wondering if this is some kind of android issue..
- 08-02-2012, 07:13 PM #4
- 08-02-2012, 07:16 PM #5
Some applications won't show every city. I use BeWeather and like the interface.
Reply
