Results 1 to 16 of 16
    Default Which car charger would be better for the GS3?
    Or
    Any advice is appreciated.
    Sent from my GT-I9300 using Android Central Forums
  2. #2
    slbuck's Avatar
    Posts
    ROM
    Clean Rom 2.1
    Default
    I've been using this one, and plan on using it for my new Sammy.
    http://m.androidcentral.com/accessor...al-car-charger
    Thanked by:
  3. #3
    Default Re: Which car charger would be better for the GS3?
    I will be using the OEM one on Shop Android on this site. Prefer OEM to avoid explosive situations.
    Thanked by:
  4. #4
    firetruck41's Avatar
    Posts
    ROM
    Stock
    Default
    Quote Originally Posted by zizu101 View Post
    Or
    The first one should work. The second one is mini-usb, so it won't fit. The S3 takes a micro-usb like most smartphones.
    Sent from my DROIDX using Android Central Forums
    Thanked by:
    Default
    Quote Originally Posted by firetruck41 View Post
    Right, I didn't look carefully.
  6. #6
    abelled's Avatar
    Posts
    ROM
    CM10 w/747 kernel
    Quote Originally Posted by jcp006 View Post
    This. I've had bad experiences with knock-off, non-OEM car chargers.
  7. #7
    Bullfrog1337's Avatar
    Posts
    ROM
    Stock
    Here ya go. I have bought 2 of these in the last week. He ships them really fast.
    OEM Samsung, ya cant go wrong for this price.
  8. #8
    Amazon.com: Motorola Vehicle Power Adapter micro-USB Rapid Rate Charger: Cell Phones & Accessories
    Only $5 plus shipping if you don't have Amazon Prime.
    While Android Central has them for $15 plus $5 shipping.
  9. #9
    Quote Originally Posted by mikesmith View Post
    I have this one for my Droid and it stopped charging my cell phone. There's an issue with the connector end. Wouldn't recommend it.
  10. #10
    Quote Originally Posted by DianeR View Post
    Mine got flaky after about a year. Only charges at just the right angle now. It is however fast, and quite cheap if you have a prime account. I bought a new one to go with my S3.
  11. #11
    Quote Originally Posted by Bullfrog1337 View Post
    Unfortunately, "This listing was ended by the seller because the item is no longer available."
  12. #12
    Does anyone know where I could find a longer car charger? I had the car charger shown above in the link which I used when I traveled for work and was using in rental cars, and some cars I needed a longer cable.
  13. #13
    bworley50's Avatar
    Posts
    Global Posts
    916 Global Posts
    ROM
    Stock ATM
    Use the Motorola ones. They are the best.
  14. #14
    dna.'s Avatar
    Posts
    Global Posts
    4 Global Posts
    So with the GS3, as long as the connector fits into the phone it is OK to charge with it?
    I know back in the day we used to have to worry about power ratings (amps/volts) and how they might damage electronics but most people I talk to these days say that doesn't matter as the phones are smart enough to adapt as long as the connector fits...
  15. #15
    Default
    Just curious... will the car chargers I currently have for an OG Droid work for the S3's? If so it'll save me a few bucks.
  16. #16
    I plan on using the generic Verizon branded micro usb charger I've been using. The one that has a USB port on it as well.
    Anybody have any problems with these on more powerful phones?
