1. junglejunkie's Avatar
    So after I set up my phone, I had a voicemail notification...but when I check my voicemail, it says I have no messages.
    Now I have a voicemail notification that I cannot get rid of.
    Just wondering if anyone had any similar issues or ideas on how to fix it.
    Thanks.
    06-26-2012 10:25 AM
  2. Mikest's Avatar
    Which carrier are you on?
    06-26-2012 10:40 AM
  3. junglejunkie's Avatar
    T-Mobile USA
    06-26-2012 10:41 AM
  4. junglejunkie's Avatar
    Well I figured out how to fix my problem. I guess I will post my findings here in case anyone else runs into the same issue.
    Fix:
    -Left myself a new voicemail
    -Called voicemail and deleted new message
    -Notification is now gone
    06-26-2012 11:11 AM
  5. mbj8448's Avatar
    Thank you! Only had my GS3 a few hours and that stupid voicemail notification was driving me crazy. I tried all kinds of things to make it go away. I was on hold with TMo for about 30 minutes and no one could figure out how to get rid of it. While I was waiting, I decided to check the AC forums. Found your post, followed your instructions, and it went away. Thanks again!
    kkaland likes this.
    06-26-2012 09:29 PM
  6. junglejunkie's Avatar
    It drove me nuts...Glad I could help
    mbj8448 likes this.
    06-27-2012 07:07 AM
  7. KunYuL's Avatar
    I have the same problem but I can't do your trick because I canceled my phone plan because I am travelling abroad. I am now using my phone with Wi Fi only so I can't even access my voice mail no more. Could I perhaps switch off the phone call service since im not using it ?
    06-22-2013 10:34 AM
  8. tutisnowbird's Avatar
    I tried this using my phone, and it didnt work. I'll try using another phone
    02-21-2014 06:45 PM
  9. Austin185's Avatar
    That happened with me on my att s3. I just turned my phone off for 5-10 min and turned it back on and it was gone
    02-21-2014 08:55 PM
  10. Jimrock21's Avatar
    It worked. Thank you.
    04-02-2014 01:32 PM
  11. Toxigenic's Avatar
    Nothing has worked with my galaxy note....
    I cancelled voicemail with telus...when the notification was there..
    I didn't set up voicemail so I only get a busy signal when I call it.
    Everytime the phone is shut off and turned on the notification is there...
    I've cleared the cache but not the media data because of the warning box that pops up..
    04-06-2014 02:28 PM
