Results 1 to 11 of 11
    Disturbd1's Avatar
    Posts
    ROM
    MikG 3.11
    Default Condition the battery?
    Just wanted to put a feeler out there for those who are for or against or maybe even unconcerned with the conditioning of the battery once we (who are not yet fortunate enough) get the device in our hands. Of course, it's always hard not to play with it right away, and check everything out. That being said, I've read countless pieces of advice on the internet that suggest conditioning any Li-ion based device's battery before use. Generally what I have read is that you first charge the device for several hours (overnight is best), then use it until it's all the way dead. Charge back up again, and if you feel like repeating an additional time or 2, it is all the better (the memory cells function best when you condition it using this method for the first few charges from what I read). This worked extremely well for me as an original Evo 4G user. I have actually purchased 2 different extended-life batteries, and conditioned them both before use using the method above. It served me well.
    Thoughts?
  2. #2
    Default Re: Condition the battery?
    I was gonna start this thread as we got closer to getting the device .
  3. #3
    junglejunkie's Avatar
    Posts
    ROM
    4.1.2 Stock Rooted
    Found a neat article about this
    Thanked by:
    Disturbd1's Avatar
    Posts
    ROM
    MikG 3.11
    Quote Originally Posted by junglejunkie View Post
    This one was inside that page, talks specifically about calibration of a Li-ion battery:
    Seems legit.
    Thanked by:
  5. #5
    firetruck41's Avatar
    Posts
    ROM
    Stock
    :meh: I'm just gonna charge and go, like I did with my Droid X battery which has lasted almost two years of use without much change.
  6. #6
    So do u charge all the way at first or plug and play ?
  7. #7
    lebox97's Avatar
    Posts
    Global Posts
    7 Global Posts
    Batteryuniversity.com is an excellent resource:
    There are really two questions rolled into one here...
    1) Li-ion are generally shipped by manufacturers at 70% +/- charge - as this is deemed to be best for long term storage.
    Once put into use - li-ion perform better and last longer if topped up regularly and as needed rather than fully discharged...
    unlike NiCD/NiMH, li-ion does not develop memory over time - while regularly fully discharging li-ion shortens it's life.
    2) Calibration can be done periodically (every few months) by fully discharging the battery - for the benefit of the phone battery level gauge.
    This is NOT done for the health of the battery - it's so the phone more accurately displays the remaining charge/capacity of the battery.
    So it boils down to choice of - longer cell life, or more accurate battery level gauge?
    cheers
  8. #8
    Default
    Quote Originally Posted by lebox View Post
    cheers
    Just kidding .... Thanks for the great reply
    Disturbd1's Avatar
    Posts
    ROM
    MikG 3.11
    That part makes perfect sense, considering the first...70% of my battery life right now goes ZOOOOOOM. Then the next 20%-30% take considerably longer to go.
  10. #10
    lebox97's Avatar
    Posts
    Global Posts
    7 Global Posts
    I put the new device on charge/r the moment I pull it out of the box...
    and then play with it WHILE it's topping up-charging.
    Quote Originally Posted by NIKSTORM View Post
  11. #11
    Default
    I used to do this... but it gets long i just buy a few spares
    Sent from my GT-I9300 using Android Central Forums
