Results 1 to 8 of 8
Like Tree4Likes
  • 1 Post By abprice5
  • 1 Post By Eaglemaniac
  • 2 Post By fotd
    Default AT&T Galaxy S3 vs GSM GNex Battery Life
    Can someone that has both comment on how the battery life compares. I have the S III and can barley make it until 10pm. Would loved to know how the two phone compare in battery life.
    PamelaBB likes this.
  2. #2
    Default
    I have the GNEX and the battery has always been an issue. It isn't the phone that's the problem, it's LTE.
  3. #3
    Default Re: AT&T Galaxy S3 vs GSM GNex Battery Life
    Quote Originally Posted by jeepentj View Post
    so you have a poor battery life on GSM GNex? which one lasts longer? the G3 or the GNEX?
  4. #4
    Default
    It depends
    If you constantly use lte and wifi the battery will drain quickly and its all because of your huge HD screen
    If you check your battery usage screen always uses nearly 50-60%
  5. #5
    shadrap's Avatar
    Posts
    Global Posts
    283 Global Posts
    The GSM Galaxy Nexus does not have LTE. You must have the Verizon Galaxy Nexus which does have bad battery life.
    BassRumors - bass fishing forum.
  6. #6
    32nm microprocessing is more energy efficient than 45nm, also HKMG reduces current leakage alot compare to PolysiOn. (like 1/100)
  7. #7
    Are we really having this discussion? It's not even close. And to the OP, dude, you can make it to 10pm!! That's an accomplishment with LTE and a 4.8 HD screen. What else do you want?
    scorpiodsu likes this.
  8. #8
    Quote Originally Posted by Eaglemaniac View Post
    I could barely make it to 10AM when i first got my thunderbolt.
    saichick04 and socal like this.
