Results 1 to 21 of 21
Like Tree2Likes
  • 1 Post By smbrooks32
  • 1 Post By A6Driver
  • 2 Post By mmeg92
    Chdwil's Avatar
    Posts
    Global Posts
    104 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Phone screen won't turn off while charging
    When I plug my phone in at night to charge I turn the screen off and all seems well. But as soon as the phone receives a notification the lock screen comes on and won't turn off. I have it set to turn off at 15 seconds but no luck. It only does it while charging. Anyone else see this? I have thee US version, not the super duper version.
  2. #2
    smbrooks32's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Not sure if its the same for the S3 but try this go into settings, find developer options should be under the category systems, then look for stay awake if ur phone won't shut off while charging it will be checked just un check it then should be fine.
    Chdwil likes this.
    Chdwil's Avatar
    Posts
    Global Posts
    104 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Phone screen won't turn off while charging
    Quote Originally Posted by smbrooks32 View Post
    I can't find that option anywhere.
  4. #4
    smbrooks32's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I'm saying that when you pull down settings that u will have to look around I do not own one or played with it but what your looking for is called stay awake. It makes your phone stay on while charging. Look under display, on my nexus its under developer options
    Chdwil's Avatar
    Posts
    Global Posts
    104 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think I have it fixed. Simple fix I was overlooking. In settings menu, dock, keep home screen on. I turned it off, not sure how I turned it on to begin with. Thanks for the suggestions
  6. #6
    smbrooks32's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Yeah sorry could be more help how are u liking it so far and pros and cons you can give
    Chdwil's Avatar
    Posts
    Global Posts
    104 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have used a 4s, one x, and skyrocket in the last year. So I have used all of the top tier devices. The G3 and One X are very even in my opinion. If it wasn't for lack of expandable memory I probably would have kept the One X. The camera on the One X was outstanding and the screen was in a league of its own. Compared to the Skyrocket The G3 is very similar. The G3 is what I would call the Skyrocket on steroids, it does everything smoother and faster than the Skyrocket. Out of all the devices the 4s has the best camera, but that's about all I would say it could do better. I do like the look of the G3 pebble Blue, but all of the devices look great.
    G3 pros
    Does everything smoothly and fast.
    LTE is blazing fast.
    Camera has lots of great features.
    There are so many shortcuts and gestures to this phone it can take a while to find them all.
    I like the look, especially the blue. It feels as good as it looks.
    Battery life is an improvement.
    I can network the phone to most of my devices at home.
    It has expandable memory.
    There should be plenty of aftermarket cases and devices on the market soon.
    Cons
    Camera is not as good as One X and 4s.
    It is kind of slick and I'm afraid I may drop it. I don't want a bulky case. I need a tacky battery cover to help grip it.
    Screen is good but not as good as One X.
    Not much else I can think of for cons.
  8. #8
    smbrooks32's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Cool thanks I have the nexus and I'm debating if I want to get the s3 or continue on with the nexus
  9. #9
    A6Driver's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The option is under Settings/Accessory/Dock/Desktop Home Screen Display = Uncheck
    ---------- Post Merged at 05:20 AM ---------- Previous Post was at 05:20 AM ----------
    toenail_flicker likes this.
  10. #10
    lesorkim's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Does this setting keep the screen on ONLY when it is on a "dock"? Maybe I only think I know what a "dock" means. Will this setting keep the phone display on when plugged into the plain old charger cord? Currently I am using the widget "Stay Awake" to get the phone to stay awake when on the charger cord.
  11. #11
    tokki75's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Red face Re: Phone screen won't turn off while charging
    OMG! I had the same issue with my Samsung Galaxy 3 screen being on during the charge and was so relieved to find the answer to resolve the issue here.
    =) Thanks guys!
  12. #12
    Mohamad Anas's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I tried that also in my note2. It's not working. Screen all not getting switched off while charging.
  13. #13
    visualmonk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unchecking the STAY AWAKE option worked for my Galaxy S4. From the home screen touch SETTINGS--MORE--DEVELOPS OPTION. Thanks for the help.
  14. #14
    mmeg92's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you are having trouble finding the "developer options" on your S4 here's how to get it:
    follow the instructions on this link
    How to Enable Developer Options on the Samsung Galaxy S4 | Haptic Antics
    my phone didn't have it visible until i followed those steps. Then you will be able to find the "stay-awake" option
  15. #15
    Gail Dix's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the same problem with my samsung note 10.1, haven't found a solution yet.
  16. #16
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Gail,
    Have you looked in the Developer options on your tablet to see if there's a similar setting? Perhaps if you posted this in the relevant forum you'd find someone that has already posted the detailed steps for your device.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
  17. #17
    funnychick82's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    mmeg92, you are amazing! Thank you for the link, worked like a charm!
  18. #18
    Peter Romanski's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    sweet jesus mmeg92 thank you. i had to register just for that piece of information. not sure how it got turned on but the "stay awake while charging" option is now off!
  19. #19
    ginette70's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you SO much for the simple instructions. Worked perfectly. GM
  20. #20
    Van_W's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had a similar issue and fixed it by first turning on "developer mode" then deselecting "Stay awake" under Settings / Developer Options. Turn on developer mode by going to Settings / About Device, then touch/tap on "Build number" seven (7) times. Once developer mode is on, go to Settings / Developer Options, and deselect "Stay awake". This resolved the problem for me. Keep in mind that each android phone is slightly different in where "About Device" is located, but it is in the Settings section. Go there and tap "Build number" seven times to turn on Developer mode.
  21. #21
    Fsuktb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My developer options are off and it is still showing display continuously
    Quote Originally Posted by GSDer View Post
    Gail,
