DEAL OF THE DAY: Save 42% on the iBOLT Vehicle Charging Dock for Samsung Galaxy S3!
Page 3 of 3 FirstFirst 123
Results 51 to 66 of 66
Like Tree9Likes
  1. #51
    Default Re: First ring low then sounds jump up - any fix for this?
    I have galaxy not 2 same problem its irritating me
  2. #52
    Go to Google play and search for Disable increasing ring
    Thanked by 2:
  3. #53
    unfortunately no answer, but i can confirm the gs3 doing this on my uncles phone.
  4. #54
    I have experience this same thing, I thought it was pocket mode but it's not it's a glitch Samsung I hope will fix in the near future maybe with JB4.1.2. I have missed some calls because of this
  5. #55
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Look at post #53!
    Works perfectly
    Please give the dev' some love on Play
    MERRY XMAS!!!X
    Unbranded rooted international s3 with Official JB. Paisley, Slotland, Western Europe :beer:
    GT-I9300, UK
  6. #56
    I just got my Samsung s3 yesterday and I've noticed this as well. I don't like it at all, but I'm not going to mess with my brand new phone to try to stop it. I wish it didn't do it, and hope that they can fix it somehow!
  7. #57
    Lightbulb Re: First ring low then sounds jump up - any fix for this?
    If you don't change your ringtone frequently, you might consider this - use an audio editor to add exactly 2 seconds of silence at the beginning of your ringtone. This way, your phone will start ringing 2 seconds later (which isn't much), but at least it will ring at a constant volume.
  8. #58
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Quote Originally Posted by Dana Rombach Hoffman View Post
    are you mental lol? :P its an app from play store which cures the bug lol..... use it! it works!
    Unbranded international rooted s3 with Official 4.1.2 JB. Paisley, Scotland, Western Europe :beer:
    GT-I9300, UK
  9. #59
    The app is called disable increasing ring.
  10. #60
    Try This
    Click on Phone(App) > Menu button(Left Key) > Call settings > uncheck Increase volume in pocket (Ringtone volume increases when device is in pocket or bag).
  11. #61
    I can confirm that it is doing it on my Galaxy S3 as well...quite annoying. I might try downloading that app and see if it fixes it. My phone is rooted, but I'm not going to so anything with that yet, it's not worth the risk and the ring bug isn't going to kill me lol.
  12. #62
    Just to be clear, this isn't a "bug." The intent is that if you're in a quiet place, you can answer before the ring gets really loud. In a noisier place, it will get loud enough to hear after the first few rings. It would be nice if you could turn the feature on or off, though.
    PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
    If I've helped you, please press the Thanks button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
  13. #63
    I got a solution for the ascending volume on samsung S3 , I found an app on play store " crescendo volume" it helps you to minimize the volume of descending volume to one second which is barely heard when you phone is ringing. It helped me a lot because i was annoyed by this descending tone, hope it helps you too.
  14. #64
    I have the new Galaxy S 4 and it does the same thing - ring starts off low, then jumps to full volume. I downloaded this app to disable this problem, and it works like a charm. Does anyone else have the same problem with the Samsung Galaxy S 4?
    erosinelysium likes this.
  15. #65
    What app did you use?
  16. #66
    I have noticed this as well on my GS4(where your ringtone starts out very soft for a second or two and then goes to full volume) and it drove me nuts all day til I read further up in the thread about this app: "Disable Increasing Ring". It's free and it worked like a charm.
    The questions I still have are:
    1) Was this by design on Samsung's part?
    2) If it was by design, why isn't there a way turn it off/on? No other setting will fix this, I have tried them all. You HAVE to install the app or just live with the second or two of soft ringtone before it jumps instantly to full volume.
    3) I was on Verizon before(miss those guys cause Sprint's network is sloooooow) and never had this issue with my GS3 while on Verizon. Was this issue due ot my phone number being ported over from Verizon to Sprint possible?
    4). Does Samsung have any plans to fix this with an update? It's a small nusance but big enough of one to make me install the app to fix it. I would like it fixed by Samsung and or Sprint though and not have to use an app.
    Also, has anyone else noticed that the GS4 is NOWHERE near as smooth ast the GS3? It's barely noticeable but the GS4 seems a tad glitcthy. Most folks are blaming it on TouchWiz being so bloated on the GS4. I hope Sprint/Samsung release some updates/fixes.
