Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 85
Like Tree7Likes
  1. #51
    fupayme's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: My battery life sucks. How about yourself?
    This is why I love this phone. First day of full charge and still going! Mild user, but it's my usage that really matters to me. Just saying.
  2. #52
    dafoot2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Here's my Screen usage that goes with My page 2 post.
  3. #53
    dafoot2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try this again
  4. #54
    Paul627g's Avatar
    Posts
    Global Posts
    17,762 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Battery life is such a hard thing to judge. So much depends on what we each consider a "Mild user or Power user". Also take into consideration what are we doing? Picture or graphic extensive emails? Picture/Video texting? Youtube? Social media with constant updating to Twitter or FB? Music streaming? You get the picture..
    There are so many variables to take into consideration its hard to judge anyone's battery life in particular.
    Only way to really isolate what is going on is to attempt to change your daily habits... Example tomorrow take a break from your normal social media if that is your thing, see if your battery life improves.
    brava27, crzycrkr and Alfonsca like this.
  5. #55
    Forgetful's Avatar
    Energy hoarder
    Posts
    Global Posts
    1,473 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    stock rooted
    From what I've seen this phone is pretty good as far as battery life for recent androids.
    guys/gals, your phone will not go 8 hours with all of that being screen on time. No phone will without a extended battery (or Max).
    If you can get 4.5 hours of screen on time per 24 hour period (with not many calls and the brightness at 25-45%) using wifi/3g then be very happy. 4G will drop that by a large amount too.
  6. #56
    comshock25's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Mine last for about 8 hours with extensive use. I use it at the commute going to the office. That's one hour commute. From 100 down to say about 80 percent when I reach the office.
    Sent from my GT-I9300 using Android Central Forums
  7. #57
    ungibbed's Avatar
    Posts
    Global Posts
    252 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    T-mo stock ROM(JLB 4.1.1)
    I average around twelve hours with moderate usage.
    Screen brightness set to roughly 30%
    Bluetooth off but all other radios active
    4G enabled
    Haptic feedback off entirely.
    When at home, WiFi calling is enabled (without it, my phone drops to EDGE and constantly fights for a HSPA+ connection). This is a major factor in the longevity of my battery.
    The killers for me are the typical issues.
    Camera usage for stills and 1080p video capture.
    Demanding games such as Modern Warfare 3 and N.O.V.A. 3
    Finally, web browsing with sites that use Flash heavily.
    My other difference is due to my Galaxy S2 using the 1.5Ghz Snapdragon series 3 processor and Adreno 220 GPU. I wish T-Mobile could have used the Samsung chipset but the difference in networks called for different hardware.
  8. #58
    Roboticz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yesterday I used my phone heavily with internet browsing, Facebook, couple phone calls, video games, a LOT of messaging, etc... and my battery lasted 11 hours.
  9. #59
    Tkbredx's Avatar
    Posts
    Global Posts
    2,123 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    TeamSonicFreeGS3 v9.1
    Default
    I am a power user. I would last about 10 hours but every opportunity I get to charge my phone. I charge it so I cab usually last the entire day.the screen takes up most of my battery usage. I've adapted to having the brightness all the way down and using power saving at all times (is that bad? Does it allow my phone down?)
    And when shall we see extended batteries? I've seen a couple on amazon but I don't trust them.
  10. #60
    splashattack's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have poor signal inside my house. It usually stays between -95 to -103 dBm and the restroom is a complete Sprint dead zone :P so on mobile network I get about 3 hrs screen on time. On wifi over 5 maybe 6. Havent run the battery down to zero as of yet
    Sent from my SPH-L710 using Tapatalk 2
  11. #61
    Soundtrack to Chaos's Avatar
    Banned
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I use wifi when I'm home so that greatly helps battery life.
    You should also reset your refresh intervals to manual instead of auto
  12. #62
    bbolumen's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have a Droid Charge by Samsung and I only get 5-8 hours on the battery. Setting say Display is 80%, email 4%, Android System 4%, Android OS 3% ....
    As long as I am at work I have it charged by my computer so it keeps at 100% but when it is in my pocket with a couple of phone calls and emails only, the most I normally get is about 7-8 hrs before it gets below 25%.
    I now bought 2 batteries to keep fully charged because the car charger I have (2 of them in fact) will not charge because the phone is "too hot" which happens when I try and use the GPS which drains my phone very quickly.
  13. #63
    Disturbd1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MikG 3.11
    If you ask me, it's most definitely screen time + cell radio. I've had mine for 2 days now. 1st day I was astounded at how long the battery lasted. As others mentioned, it wasn't long before I began to put "my apps" back on using Titanium Backup. After fiddling with the discrepancies between GB and ICS, and getting the proper versions of my apps back...I noticed quite a drop in battery life. Primarily when I'm at work. I have 1-3 bars sometimes, and other times absolutely nothing (I.E. it's searching for 3G, we have no LTE here yet). That said, my old Evo had the same behavior, so at least I can say it's not a crappy cell radio in the unit. If anything, it's better. It DOES, however, definitely use more battery to power it. I've found no way to tell the phone to differentiate between 3G and searching for LTE, so I assume that isn't really the problem. I've got 8h 0m on battery, with 29% of use being screen time, 27% Cell Standby, and 12% voice calls (I made one call for about 30min over lunch, and received one that lasted MAYBE 2-3min prior). I'm sitting on 35% battery right now. To me that is....meh. Not terrible, but definitely not great. Screen-on time is 1h 5m.
    EDIT: I never have GPS on, unless I'm going to use it. I never use BT. Also, I can't get on WiFi at work, so that is why the in-depth explanation of my 3G woes above.
  14. #64
    calcheese's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i'm only averaging about 10-12 hours with a screen on time of 3 - 4 hours and a 20-30 mins calls.
    i do have 2 email accounts set to push and 1 to sync every hour.
  15. #65
    adelcastillo78's Avatar
    Posts
    Global Posts
    218 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So when are the extended batteries at the oem size going to come out?
  16. #66
    chaunsey's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    poor signal is definitely big, first day both my brother and i got great battery, around 6 hours of heavy use with like 3 of screen time dropped me by only around 40%.
    last 2 days with moderate use we both got down to around 20-30% after 8hours, maybe 1 hour screen time, and both data and sync off.
    the reason being we were working in an area kind of out in the sticks, we only had roaming coverage and barely a signal at all, the phone ends up constantly trying to stay connected.
    another thing to look for is awake time vs screen time, in the battery stats you can see the screen and awake time bars next to each other, they should be mostly the same, if you have a lot of times where the phone is awake when not using the screen, then you have apps and stuff that are keeping your phone awake when you're not actively using it.
    sync is a big drain too, your phone ends up constantly updating stuff, i turned it off, and honestly it doesnt matter much, plus the s3 has "shake to update" so instead of sync, when you want to check email and stuff that needs to update, just shake the phone, and voila! updated.
    other than these few issues, normally my phone is getting excellent battery life especially when you consider the sheer power and features its running. i imagine it will only get better with updated and as people learn more about how to streamline this phone, especially if you root.
  17. #67
    hoovhartid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Disturbd1 View Post
    I have 1-3 bars sometimes, and other times absolutely nothing (I.E. it's searching for 3G, we have no LTE here yet). That said, my old Evo had the same behavior,.... found no way to tell the phone to differentiate between 3G and searching for LTE, so I assume that isn't really the problem........
    I am assuming based on the evo comment, and lack of 4g, that you are on sprint.
    if so, the 4g radio on the phone is turned off....hence the lack of problem searching for 4g signal
    settings>more settings>mobile networks>network mode> will show that "CDMA" is selected...to turn on 4G you would select "LTE/CDMA" instead.
    but don't do this until you know it is in your area
  18. #68
    bauer2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    This was with alittle below average usage do I would say that's pretty darn good.
  19. #69
    zbStylez's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I will try to post a screen shot tomorrow, but today was brilliant. It is my 4th day with the SIII. I unplugged about 0600, went to work which is a 45 min commute listening to music and fiddling with it. I do get e-mails and text at work, minimal browsing. by 1600 (10 hours of usage) I was sitting at 80%. My battery is just a monster when it comes to surviving. I started playing with it alot more downloading apps, widgets, rearranging everything, talking to the girlfriend etc... by 2300 I was still left with 40% in the battery...
    So either I got really lucky with a good battery or you guy shafted with a defective battery.
  20. Thread Author  Thread Author    #70
    brava27's Avatar
    Posts
    Global Posts
    710 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by zbstylez View Post
    i will try to post a screen shot tomorrow, but today was brilliant. It is my 4th day with the siii. I unplugged about 0600, went to work which is a 45 min commute listening to music and fiddling with it. I do get e-mails and text at work, minimal browsing. By 1600 (10 hours of usage) i was sitting at 80%. My battery is just a monster when it comes to surviving. I started playing with it alot more downloading apps, widgets, rearranging everything, talking to the girlfriend etc... By 2300 i was still left with 40% in the battery...
    So either i got really lucky with a good battery or you guy shafted with a defective battery.
    impossible....
  21. #71
    jerseygirl's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am quite pleased with the battery. For the first time in a long time, I comfortably left my house without lugging the charger with me. I had close to full charge at 5pm and went to 4th of July barbecue. While there I let my uncle play with the phone (looking at pics, videos on youtube and IMDB, and d/l apps )etc. I took pictures, let my daughter play Angry Birds and just plain fiddled with it because it's still new and hard to put down. My poor Evo would not have lasted all of that. I'm home now with 50% left on the battery and was in a pretty low signal area until I connected to my gramma's wifi. The other day, with moderate usage the battery lasted17 hours, almost all day! I wasn't doing anything too intensive...a couple of foursquare checkins, looking at pics, playing wwf and checking emails. So, no complaints from me in that dept. Mind you, I also have the settings on the power save option so I'm sure that helps.
    Edit: I forgot to mention that I was also using a live Fireworks wallpaper. I am at work now, it's 10:16am and I have 12% battery left. Screen time on is 3h 18m. Total time on battery 17h 46 min. Oh yeah, I'm doing my happy dance :-)
  22. #72
    Banned
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Got a lil over an hour on wifi and down to 80%, not bad, considering it would be like 70 something % on sprints 3g lol
    Attachment 29557
  23. #73
    zbStylez's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by brava27 View Post
    impossible....
    3 hours and I lost 5%....
  24. #74
    GrooveRite's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My battery life is AWESOME!!!! True story!!
  25. #75
    AppleSuxAndroid'sD1K's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My battery life is great now. It sucked in the beginning when I started downloading some apps here and there but I downloaded this advanced task killing app recently and the battery life has significantly improved!
    After a moderate use with messeging apps and etc still 81% after 10 hours. Screen time was about 53 minutes and stay awake time was only about 4 minutes.
