Results 1 to 16 of 16
- 07-11-2012, 10:13 AM
Thread Author #1
Smart stay?
I'm curious to hear how others are experiencing smart say (screen stays on if you're looking at the screen). Thus far, I have found it to be somewhat finicky. I know I have it enabled, and it sounds like conditions have to be just right for it to work, but are there any tweaks anyone has implemented to improve performance?
Sent from my SCH-I535 using Android Central Forums - 07-11-2012, 10:18 AM #2
- 07-11-2012, 10:45 AM #3
You have to hold the phone at the right angle for it to work. Once you figure out the angle it likes it works pretty well.
Sent from my SPH-L710 using Android Central Forums - 07-11-2012, 11:27 AM #4
Re: Smart stay?
I've also found that ambient light also affects smart stay- my living room in the evening has pretty subdued lighting and I find my screen goes off after I see the 'eye' about 50% of the time. Seems if it is a dimly lit room then smart stay can't see your face well enough.
- 07-11-2012, 11:37 AM #5
Re: Smart stay?
In the dark, it doesn't do well.
- 07-11-2012, 04:31 PM
Thread Author #6
- 07-11-2012, 05:25 PM #7
- 07-11-2012, 05:49 PM
Thread Author #8
- 07-16-2012, 09:50 PM #9
Re: Smart stay?
For me, it never works when I wear my glasses. If however I take my glass off it does work. The problem I have is I need my glass to see the phone.
- 07-16-2012, 11:05 PM #10
- 07-17-2012, 12:12 AM #11
- 07-17-2012, 05:28 AM #12
- 07-17-2012, 07:52 AM #13
- 07-17-2012, 07:55 AM #14
Re: Smart stay?
I have no complaints.... Even though it doesn't work in the dark and even though it works about 80%.of the time in light.... I still love it.... I don't wear glasses though
- 07-22-2012, 06:33 PM #15
- 07-22-2012, 06:52 PM #16
Reply
