Actually describing Apple as elitist is NOT off the mark. Some were upset by that comment, however switching the sheild for the ring does NOTHING to increase sound quality. Coaxial cables have a woven SHIELD around the audio/IF/RF wires contained within. Having the wires carrying the signals on the inside of the cable with a woven shield isolates them from external signals for radio, TV, and even signals from florescent lighting. Shortening this milimeters has no noticeable effect, but also does not increase sound quality. Also twisting the left, right and mic wires together allows some cross talk between the two channels, so inside of most cables, each channel has it's own shield. Please note I said most. The reason I said this is simply put, cheaper cables often have one shield for all three wires, or just another wire for ground that does not shield the others. Some cables shield the left and right in one shield, and the mic in another. This is a compromise between quality and expense. Having a left and right channel twisted together may cause some cross talk, but since audio in both is very similar most people don't notice any difference. Lastly this is not the only place Apple goes out of their way to be different. Their power plugs have always been different. when Androids adopted the microUSB in stead of the many multitudes of power cords used by phone makers prior to that, Apple needed a smaller micro sized plug too. So what did they do? Did they too adopt the microUSB? NO! They instead design one Wholey incompatible. Apple computers, largely incompatible with Windows or Linux, used only Sonet processors until they could not get processors that could compete with Intel and AMD processors in PCs. So did they bow down and just use Intel chip sets everyone else did? Ummm. Sort of??? They used Intel Processors, even Intel compatible chip sets, but then added a chip that did NOTHING but more or less identified it as a Mac. You could NOT run Mac OS'es on anything BUT a MAC... Why? No reason that seems logical, at the time their computers cost more for the exact same motherboard as a Windows Machine with only that proprietary chip that seemingly does nothing except allow Mac OS identify it as a Mac. If fact if they just would have made Mac OS run on all Intel/AMD machines they might make more money selling Mac OS! The ONLY time in Apple history that I can think of when did NOT make their stuff proprietary was the Apple II. They did not have the resources and started out building those in their home garage!
