Results 1 to 3 of 3
    Default changing the default lock screen?
    Is there a way to change the layout of the stock lock screen? I'd like to not have the dock icons at the bottom
  2. #2
    Default Re: changing the default lock screen?
    you want different icons on your lock screen?
    Settings > Security > Lock Option Screen > Shortcuts. Click on the area next to the toggle switch. From there you can change the dock apps on the lock screen
  3. #3
    There are programs to change the lock screen. I believe GO makes one that's free and there's Widget Locker as well.
