Not sure if this has been posted, but doing this will make windows recognize both the internal memory and the sd card as a hard drive.
Download Anycut.
Install and run
-New Shortcut
-Activity
-USB Setting
-OK
Return to homescreen and find the icon
Click
Select "Mass Storage"
Click OK
Kies is now turned off and your phone will be recognized as a hard drive (even though Windows 7 says it is a Portable Media player). Just double click on it and you have access to both the internal memory and the sd card.
For verizon users, make a shortcut to "HiddenMenuWifiOffload" to disable those annoying wifi popups.
Download Anycut.
Install and run
-New Shortcut
-Activity
-USB Setting
-OK
Click
Click OK
