- 07-17-2012, 12:00 AM #26
- 07-17-2012, 12:01 AM #27
- 07-17-2012, 05:51 AM #28
I'm not sure anyone has explained how to disable the bloatware?
Sent from my SGH-I747M using Android Central Forums - 07-17-2012, 06:02 AM #29
Re: Great battery improvement
same way but you need to uninstall any updates that you have done first for the bloatware. Then you can disable them.
HTC One (ATT GSM)
Palm Pre- > HTC Evo 3D > HTC One X (White) > Samsung Galaxy S3 (White) > HTC One (Silver)
If any of my posts help you don't forget to thank/like it!! - 07-17-2012, 06:10 AM #30
- 07-17-2012, 06:12 AM #31
- 07-17-2012, 08:21 AM #32
- 07-17-2012, 08:22 AM #33
You know I never even saw the VM app.
HTC One (ATT GSM)
If any of my posts help you don't forget to thank/like it!!Thanked by: - 07-17-2012, 08:23 AM #34
- 07-17-2012, 08:25 AM #35
Here are some apps that I want to disable but worried it may hurt proformance. Take a look. The ones with the Android icon.
Sent from my SGH-I747M using Android Central Forums - 07-17-2012, 08:27 AM #36
- 07-17-2012, 08:33 AM #37
dont disable any android/google apps. i remember i uninstalled one by mistake on a rooted phone + it stopped the playstore etc from workin. u cant really do much harm by just disabling apps but basicly only disable ones that u can see in ur app drawer but dont use (bloatware)
- 07-17-2012, 08:42 AM #38
Thanks for this tip guys. It helps battery for sure.
I also disabled a few more while I was at it.. Like sprint connection optimizer and all share since I won't use em
Sent from my SPH-L710 using Android Central Forums - 07-17-2012, 08:44 AM #39
- 07-17-2012, 08:51 AM #40
no problem man
- 07-17-2012, 08:52 AM #41
- 07-17-2012, 08:57 AM #42
maybe its a visual voicemail app like Hullomail? my s3 doesnt have it
- 07-17-2012, 12:06 PM
Thread Author #43
Don't disable those. When we're talking about bloatware, we mean in your app listing, not all the services and stuff. For example, open up the app tray. If you click and hold any of those apps, drag them to the "app info" area on the bottom. It will tell you about the app, and give you the option to disable. Some apps (bloatware, or any preinstalled app) will require that you uninstall updates first, but that option is in the same place i just told you. I'd say as long as you're just dragging the actual apps like that, you probably won't disable any important service. If you do find something not working right, simply re-enable whatever you last disabled to make it work again. Shouldn't run into any problems. I got rid of almost all the google and samsung apps this way, because I don't use a lot of them. I did keep the important ones for me though.
- 07-17-2012, 12:13 PM #44
- 07-17-2012, 12:14 PM #45
- 07-17-2012, 12:36 PM #46
I thought this was common knowledge, that is the first thing I did when I got my phone. ICS introduced this feature. Below is what I have disabled.
1. All share controller
2. All share play
3. All share Service
4. Backup Assistant Plus (Verizon)
5. Apps (Verizon)
6. S suggest
7. Facebook
8. Amazon Kindle
9. Color
10. My Verizon Mobile
11. V Cast Tones
12. VZ Navigator
13.Yahoo Finance
14. Yahoo News
15. Media Hub (Samsung) ****I will stick with the "Play Store". - 07-17-2012, 12:41 PM #47
I've disabled....
Sent from my SGH-I747M using Android Central Forums - 07-17-2012, 12:48 PM #48
- 07-17-2012, 01:38 PM #49
- 07-17-2012, 01:47 PM #50
Reply
