Page 4 of 4 FirstFirst 1234
Results 76 to 99 of 99
Like Tree6Likes
  1. #76
    Kevinskeep's Avatar
    Posts
    ROM
    Stock
    Default
    Quote Originally Posted by sparksd View Post
    Probably something simple I am missing but after executing --
    Settings > Application Manager (all) > S Voice > Disable.
    How do you re-enable it? I go back into Application Manager after disabling it and S Voice no longer shows up (I did check under "All").
    Dave
    Go all the way to the bottom of the list, disabled apps automatically get put at the bottom
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
  2. #77
    Default Re: Great battery improvement
    Quote Originally Posted by Kevinskeep View Post
    This has been covered about 5+ times already in this thread
    Rev.
    Galaxy S3
    Ubuntu Linux 10.04
    IT Tech
  3. #78
    Default
    Lol at people trying to disable every little thing now they know it improves battery.. just shows what crap comes preinstalled on these devices
    Sent from my GT-I9300 using Android Central Forums
  4. #79
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    totaly lol. just glad my s3 was sim-free so its only samsung crap + no network crap :-)
  5. #80
    kmf1's Avatar
    Posts
    Global Posts
    122 Global Posts
    Default
    I disabled a number of apps. We will see how it works regarding the battery life. Certainly a nice ICS feature to disable and not un install in case the apps are needed in the future.
    Sent from my SCH-R530U using Tapatalk 2
  6. #81
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default
    Quote Originally Posted by kmf View Post
    yeah hope JB doesnt lose the feature
  7. #82
    Default
    Quote Originally Posted by funkylogik View Post
    then you dont get chance to double press coz the 1st press just takes u home.
    i dont understand how disabling s-voice improves battery either, it doesnt show up in battery stats + i havent a way of really testin it but i disabled everything i dont use + cant uninstall anyway + a lot of people here have noticed definate improvements so its all good in the hood
    I have it and all the Verizon crap disabled and I'm getting great battery life. I've been off charge since 830am its now 805pm and at 54%
    Tapatalk'd from my Galaxy S3
  8. #83
    Default
    Quote Originally Posted by soccerdude2014 View Post
    I can't find S Voice anywhere in my list or at the end of it either. What is S Voice anyhow?
  9. #84
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default
    Quote Originally Posted by InkedAdrenaline View Post
    yeah luckily my s3 is unbranded so it only has samsung bloat
  10. #85
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default
    Quote Originally Posted by Kcled01 View Post
    to disable s-voice, go to settings, application manager, press ALL at top of screen then scroll down till u find it, list is alphabetical and svoice has a blue microphone icon. its just a voice search app by samsung and IMO googles voice search is better. also to speed up going to homescreen, disable the home button "double tap" for s-voice (think its in "motion" settings but im not sure
  11. #86
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    ...im guessin the reason u cant find it is coz ur lookin at downloaded apps in app manager so remember to tap "all" at the top
  12. #87
    Does anyone know what com.samsung.vvm refers to? It says Voice Mail within the Services tab. But I use Google Voice. Should I disable it?
  13. #88
    Default
    This is a great thread excited to see what it does tomorrow on a full charged battery thanks for the tips everybody!
    Sent from my SCH-I535 using Android Central Forums
  14. #89
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default
    Quote Originally Posted by Issemann View Post
    i tend to leave the com. apps alone
  15. #90
    Default
    To disable the double click lag you must go into the s-voice settings and turn off "double tap home". Just disabling the app doesn't stop the button lag (at least to me it didn't seem to) . So before disabling the app, disable the double tap.
    Sent from my SCH-I535 using Tapatalk 2
    Thanked by:
  16. #91
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default
    Quote Originally Posted by fotd View Post
    yeah do both
  17. #92
    You can also try turning off WiFi, BT and GPS when not in use. Try to lengthen refresh rate of apps like BeWeather or AccuWeather or even setting them to manual.
  18. #93
    Quote Originally Posted by jcp007 View Post
    This is a weird place to make a first post, but, I just used this thread to disable a bunch of stuff, but I don't even use weather, so I disabled that as well. Now I'm wondering if I get a little too disable happy.
  19. #94
    mumfoau's Avatar
    Posts
    Global Posts
    886 Global Posts
    I'm late to the party but let's see how much an improvement disabling the bloat provides.
  20. #95
    Quote Originally Posted by iliketowel View Post
    You can easily re-enable anything you change your mind about. In the Application manager, scroll all the way to the right, to the "All" tab. The scroll all the way to the bottom of your app list. All your disabled apps are grouped together down then, and you can re-enable the same way you disabled.
    PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
    If I've helped you, please press the Thanks button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
  21. #96
    nj1266's Avatar
    Posts
    Global Posts
    254 Global Posts
    Default Great battery improvement
    I like this thread. I did disable some of the bloat ware on an S3.
    Sent from my iPhone 7
  22. #97
    dude how do u disable this gestures..
  23. #98
    just download juice defender free, and set it to balanced so you still get notifications every 15 minutes (Calls and text will still come through like normal) It has worked for me. I went over 1 day on my battery with moderate to heavy use. Try it out.
  24. #99
    Quote Originally Posted by Numan Ali View Post
    You go into settings/motion and click off
    All animals are equal but some are more equal than others
