1. graciemarie14's Avatar
    I am having trouble deleting an empty home screen. I go to edit homescreen and attempt to drag screen to the trash can, but it doesn't delete. The trash can turns red but home screen remains. Any other suggestions?
    07-19-2012 09:16 PM
  2. jeffreii's Avatar
    Might need a reboot and try again? Not sure but I know you can't delete your last remaining homescreen, which I doubt you are trying. Perhaps make sure it's not set as your default screen (I think denoted by a star)? Just some ideas.
    07-19-2012 09:52 PM
  3. graciemarie14's Avatar
    Thanks, rebooted and it worked. Go figure.
    07-19-2012 10:12 PM
  4. jeffreii's Avatar
    One of my favorite things to say: "nothing is broken until you reboot it and it still doesn't work"!
    Glad it's fixed for you.
    07-20-2012 07:11 AM
  5. DixieChick79's Avatar
    I have this same problem in a sense. I use to be able to hold down on the blank screen and drag it to the trash bin at the bottom. However, now? I can't even get the blank screen to drag. I did a reboot (restart) and it didn't help. Any other suggestions?
    03-13-2013 10:33 AM
  6. Morgan Leininger's Avatar
    For Galaxy Note 10, just pinch any home screen and you'll be brought to a screen with all your homescreens as thumbnails. Tap and hold a scdeen and drag and drop to the trashcan at the top of the screen.
    03-19-2013 02:45 PM
  7. geekymcfly's Avatar
    On the gs3 you hit the menu key and edit page. Grab the blank page and drag to trash. Im hoping you have a gs3 since you posted in a s3 thread
    Sent from my SGH-T999 using Android Central Forums
    03-19-2013 02:58 PM
  8. Kryptonitejunky's Avatar
    Thanks mate. So simple. (Couldn't find the answer on the device's help tutorial)
    geekymcfly likes this.
    03-22-2013 04:49 PM
  9. geekymcfly's Avatar
    Yw
    All animals are equal but some are more equal than others
    03-22-2013 05:23 PM
  10. airbus737's Avatar
    Thank YOU! Squeezing the home screens WORKS GREAT for the Samsung Galaxy Note I and Note II. Next month, when I forget how this was accomplished, I'll have to find this site again, but for now you've been a blessing.
    04-02-2013 02:25 PM
  11. MsCharm's Avatar
    Oh my gosh, thank you do much for your help. This has been driving me nuts!
    05-15-2013 08:25 AM
  12. LaurieMatte's Avatar
    Thank you! Thank you! Thank you!
    for galaxy note 10, just pinch any home screen and you'll be brought to a screen with all your homescreens as thumbnails. Tap and hold a scdeen and drag and drop to the trashcan at the top of the screen.
    06-26-2013 05:37 PM
  13. Tara Innes's Avatar
    Omg I had a Samsung galaxy ace for a just over a year I could never work out how to get rid of all my extra screens drove me crazy! now I have had s3 for a while, its does the same THANK YOU I am now sain lol x x
    07-31-2013 08:28 PM
  14. happyone3's Avatar
    I could kiss you THANKYOU. I have a galaxy s3, This has been driving me bonkers for the past few months. happy dance!
    09-07-2013 04:35 AM
  15. ashleyjdean's Avatar
    Thank you so much. I was struggling with figuring that out as well...
    09-13-2013 04:39 PM
  16. petes designs's Avatar
    Drove me nuts. Absolutly nothing anywhere about how to do this. Your advice is spot on. Thanks a bunch.
    11-07-2013 07:27 PM
  17. Schivas's Avatar
    It is very easy. You just sqeeze (pinch) the sceen on home screen. Then you just drag the unwanted screen to the trash can either on top or bottom of the screen. This way you can drag all the unwanted screens. Hope this resolves your problem.
    GSDer, Bob31464 and Bob Davies1 like this.
    05-27-2014 03:55 AM
  18. AxlMyk's Avatar
    After 2 years, it probably got done.
    AC App on SGS3
    05-27-2014 10:10 AM
  19. Kurt Bolsens's Avatar
    Thanks Geeky !!
    For me that was the answer I needed !
    02-19-2015 02:18 AM
  20. Bob Davies1's Avatar
    Perfect thanks a lot
    06-25-2015 10:55 PM
  21. Beena Negi's Avatar
    Thanks for the pinching reply and it worked !!
    10-02-2015 03:16 AM
  22. nirvananow's Avatar
    Thanks so much, I've been around computers for decade, but the Androids and their OS are a mystery to me.http://forums.androidcentral.com/ima...ilies/cool.png
    05-05-2016 03:52 PM
