Page 1 of 2 12 LastLast
Results 1 to 25 of 47
Like Tree3Likes
    Default Can you silence the camera click sound?
    Yea, I want to sneak into locker rooms and take pictures of naked people.
    Kidding.
    Seriously, it's annoying. Scares my dogs. Makes people look at me when I'm taking legitimate pictures. My Resound let me turn it off.
    Can you turn it off on the S3? Can't seem to find it.
    Thanks!
    Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
  2. #2
    Default
    On Verizon if you turn off the sound of on the home screen it turns off the clock.
    Sent from my SCH-I535 using Android Central Forums
    Default
    <sigh> So I need to cut sound altogether. OK. Thanks!
    ...Sent from my Prime Infinity
  4. #4
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default Re: Can you silence the camera click sound?
    think some 3rd party camera apps have the option. i think its like law or something (maybe only in europe) that phones make a noise when u take a pic but dont think it affects 3rd party apps
  5. #5
    KreepyKen's Avatar
    Just a cool guy
    Posts
    ROM
    Unrooted with Nova Prime
    The option is there (at least on the AT&T version).
    Open the camera, tap the little gear icon (settings), scroll to the bottom of the settings list and you'll see the setting "Shutter sound." Tap it and select Off.
  6. #6
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default
    Quote Originally Posted by KreepyKen View Post
    just checked + it defo isnt in european version
  7. #7
    Default
    No such option on sprint gs3
  8. #8
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    need to use a 3rd-party cam' app for takin creepy pics then lol
  9. #9
    also not on the Verizon model.
    but, not surprising. Verizon hates it's customers
    equishd and don wonder like this.
  10. #10
    phillyphreak's Avatar
    Posts
    Global Posts
    612 Global Posts
    ROM
    leaked 2.3.3 rooted
    I love these threads.
    Thanked by:
    20blks
  11. #11
    Default
    On my Verizon one I turned off sound on phone and no camera click
  12. #12
    Default
    You have to go in the camera settings and then scroll down. I did not see it at first either.
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
  13. Thread Author  Thread Author    #13
    Quote Originally Posted by BarbecueGamer View Post
    Not on Verizon. Annoying.
  14. #14
    Default
    Yup have to put the phone on silent or vibrate. This would annoy me as well if I didn't keep my phone on vibrate all the time.
  15. #15
    Default
    That's messed up that's it's not available on your phone.... AT&T is so rocking it these days... that's the first thing I did when I got my phone.....
    ~Jae, GS3 on Tapatalk~
  16. #16
    There is a program called Samsung GS3 Toolkit V3.0 by Mark Skippen that has an option to fix the camera click, among many other cool things.
  17. #17
    The option is there on the T-Mobile Galaxy S3 for those checking.
    Thanked by:
  18. #18
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    Milestone 1/Lean Kernel
    Default
    FWIW, Google removed the option from official source/os. It is at the carrier and OEMs decision to give the option to turn this on and place the proper coding back into play to allow it. This is because there is privacy laws and such that Google did this.
    Seems like Sprint is the only US carrier that has removed the option completely to disable the camera shutter sound.
    Sent from my Nexus S 4G using Android Central Forums
    Dusibello likes this.
  19. #19
    Quote Originally Posted by Paul627g View Post
    I don't have that option on my Verizon S3. However, I can turn off ALL sounds (ringer, notifications, etc.), and it will silent the camera.
  20. #20
    On the Telus branded S3, all you need to do is turn the ringtone down to vibrate / silent. You need to do this outside the camera app (or in pull-down menu, which you can actually access in all full-screen apps by swiping down from the edge)
  21. #21
    Couldn't find it on the AT&T one, have to silence it before opening the app. Very annoying, it gets really awkward when the girls turn around and see me..
    .B
  22. #22
    travislandrith's Avatar
    Posts
    Global Posts
    8 Global Posts
    ROM
    Ultimatum S3 1.2
    Can't you just go in and delete the camera click sound file off your phone? I have an AT&T S3 so I haven't had to try, but I did that on a Verizon phone a year or so ago and it worked great.
  23. #23
    joshua.worth's Avatar
    Android Guru
    Posts
    Global Posts
    805 Global Posts
    ROM
    Android 4.1.1 Jelly Belly
    If you root you can decompile the camera app remove the sound and recompile.
  24. #24
    Silent Camera is an option, but not a very good one. You lose the features of the S3 camera that make it unique. Also, the photo quality is not very good compared to the native camera app. But if you're desperate for a quiet camera, then you could give it a try.
  25. #25
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default
    Quote Originally Posted by dotB View Post
    worse when a nun catches me pointin it under swimming pool changing room cubicle
