Results 1 to 3 of 3
- 07-20-2012, 09:51 PM
Thread Author #1
Bluetooth notification sound
I noticed that of I enable Bluetooth from the dock I get a notification sound however if I enable it b with the toggle from the settings I do not get the default notification any way to remove the sound for both?
Sent from my SGH-I747M using Android Central Forums - 08-24-2012, 04:22 PM #2
Re: Bluetooth notification sound
I have this exact same issue. I can't stand that little bird whistle when you enable bluetooth from the notification bar. Any ideas on how to turn this off?
- 08-24-2012, 05:57 PM #3
im guessing u can only change the system tone to something nicer?
Reply
