Page 1 of 2 12 LastLast
Results 1 to 25 of 48
Like Tree5Likes
    Default [HOW-TO] Use NFC Tags With Samsung Galaxy S3
    [YT]http://www.youtube.com/watch?v=84X8cV4IW-g[/YT]
    I made a quick How-To video for those curious about these neat little tags
    Thanked by 9:
    IAmSixNine and KreepyKen like this.
  2. #2
    Default Re: [HOW-TO] Use NFC Tags With Samsung Galaxy S3
    Why not use the Toggle Option?
  3. #3
    Default
    Thank you for making the video.
    It helped me understand NFC tags.
    I think I'll buy some and play around!
    Sent from my iPad using Tapatalk HD
  4. #4
    KreepyKen's Avatar
    Just a cool guy
    Posts
    ROM
    Unrooted with Nova Prime
    Thanks for the nice tutorial. Pretty easy to use.
  5. #5
    Unibrow's Avatar
    Posts
    Global Posts
    141 Global Posts
    can nfc tags enable and disable gps?
  6. #6
    technomom's Avatar
    Posts
    ROM
    Clockwork+Cyanogen 7.0.3
    Yes, that's exactly what I use them for. I use the "Switch" option. When I get in my car, I turn on GPS, turn up brightness to full, and open Maps. As I leave, I turn off GPS and reset auto brightness.
  7. #7
    where can i buy them
  8. #8
    Once a tag is programmed, can those operations be turned of while attached to the tag..?
  9. #9
    QBert's Avatar
    Posts
    Global Posts
    47 Global Posts
    So from the video you have to unlock the phone to use them? Hmm, not as exciting any more imho. I realize there are many many applications and uses for these, but I would use them mostly for switching on/off wifi and bluetooth and volume settings depending on location, but I can do that pretty easily already with a profiles app.
    I am open to the idea of the tags, will just have to think about how I would personally use them beyond what I described.
    Great video though! Thanks for putting that together!
  10. #10
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    i keep thinkin one day someones gona think of an amazing use for NFC
  11. #11
    I don't have my tags yet but one I would like to make is one that I can tap in my car that sends a message saying "I'm driving" (or something similar). I know you can set up auto-responders but I think you have to remember to turn them on and off. It might be handy to just tap your phone somewhere when you get the message.
    There are a lot of potential problems with this such as it not clearing the message so you keep getting the reminder despite having responded. And, of course, you have to unlock your phone.
    Just an idea. I know we all approach tasks differently.
  12. #12
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    having a tag in ur gf's house that makes ur sms app lock and blacklists calls and txts from a certain other girl could be handy
    dervari, crankyd00d and trucky like this.
  13. #13
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default
    Quote Originally Posted by jaj6503 View Post
    nice vid man, just watched it. one question... why "Pizza" lol
    Thanked by 2:
  14. #14
    cjb44's Avatar
    Posts
    Global Posts
    69 Global Posts
    Helpful video
    If you need to unlock your phone first does that mean I can't use a NFC to enter my password? My firm locks my phone after 5 minutes so the most common task I have is typing in a password. If I could swipe my phone to enter the password, that would be great.
  15. #15
    OWybPPgO's Avatar
    Geek Mom
    Posts
    I thought you couldn't use it to turn on GPS?
  16. #16
    jac-3's Avatar
    Posts
    Global Posts
    96 Global Posts
    Default Where to get NFC Tags
    Quote Originally Posted by equishd View Post
    I bought mine at tagstand.com.
    They have a starter pack with a bunch of different tags.
    they also have a NFC Tag Launcher that I use instead of the default. I'm still playing with the settings for using the tags though. The only thing I've done is gotten it to set an alarm. Haven't had time for anything else.
    I also found a NFC Writer, but haven't even installed id.
    Thanked by:
  17. #17
    You can also buy NFC tags at . Prices are pretty reasonable, about $1 per tag.
    Here is a link to other places you can also buy the tags:
    Thanked by:
  18. #18
    Default
    Quote Originally Posted by funkylogik View Post
    There are plenty of great thoughts and uses right now. The problem is mainstreaming them. Think about tapping it outside your front door and it unlocks and the lights turn on. Unlocking or starting your car. You could do anything...
  19. Thread Author  Thread Author    #19
    Default
    Quote Originally Posted by paparock6969 View Post
    I would think so, it more than likely wouldn't recycle the action until you've removed the device from the field than reintroduced it.
    Sent from my SCH-I535 using Android Central Forums
  20. Thread Author  Thread Author    #20
    Default
    Perhaps I should have had it launch the Pizza Hut app instead.
  21. Thread Author  Thread Author    #21
    Default
    Quote Originally Posted by cjb44 View Post
    Helpful video
    I don't think that's possible (at the moment). This almost sounds like the screen lock would have to be a third party developed app built from the ground up to be used with NFC tags.
  22. #22
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default
    Quote Originally Posted by briankurtz79 View Post
    aye u already get kits to unlock + start cars with phone but know what u mean man
  23. #23
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default
    lol yeah m8
  24. #24
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    im guessin the tags just have a simple chip with a unique i.d. and youre not actualy programming the tag but tellin the phone what u want it to do when it detects that i.d.?
  25. #25
    with NFC task launcher you can also setup a tag that switches between different profiles. So you can use the same tag to e.g. setup and disable your car settings.
    How did you actually setup the tag to launch android central forums within your browser?
    kr Andrew
