Results 1 to 10 of 10
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    ROM
    touchejiz
    Default will Galaxy Note II be more powerful than sIII?
    i love seein my phone at top of benchmark results.. anyone think the new Note will beat it?
  2. #2
    Mikest's Avatar
    Posts
    Global Posts
    765 Global Posts
    Default Re: will Galaxy Note II be more powerful than sIII?
    more than likely yes
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    ROM
    touchejiz
    i think its gona come down to battery life.. the note has a bigger screen to drive but at same time it can fit a bigger battery because people who buy the note arent gona be too worried about a bit more thickness. i think itl be quad core with 2gb ram
  4. #4
    ibcop's Avatar
    Posts
    Global Posts
    3,918 Global Posts
    ROM
    Stock
    It's gonna be a beast, you can count on that. And I can count on getting one.
    If it shows up.....
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    ROM
    touchejiz
    Default
    Quote Originally Posted by ibcop View Post
    If it shows up.....
    as well as an s3?
  6. #6
    Default
    I have the S3 and I love it and if the note 2 comes to Sprint I will definitely get that as well.
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    ROM
    touchejiz
    whats the point in having s3 and note? wouldnt u rather have the s3 for ur pocket and a nexus7?
  8. #8
    Most likely it will be more powerful. In real world usage it will probably feel the same though.
    There won't be any apps available in the next 2 years that the GS3 won't be able to handle, so more hp isn't going to do much other than for bragging rights.
    If you want an even bigger screen, the note 2 is a pretty easy choice. If you just want higher quadrant scores, meh.
    -Suntan
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    ROM
    touchejiz
    lol@"meh" i know.. im sad
  10. #10
    Default
    I feel like the screen on the s3 is a perfect medium, but I'll definitely be checking out the note 2
    Sent from another Galaxy.....S3
