Results 1 to 19 of 19
    Default Phone heat while not in use.
    S3 is heating up while not in use. is there something wrong with it?
  2. #2
    Default Re: Phone heat while not in use.
    It's it plugged into a charger?
  3. #3
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    id check if any apps are running while the screens off
  4. #4
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    ....maybe turn off wifi?
  5. #5
    Mine was doing the same thing and I had to return it
  6. #6
    GMJeff's Avatar
    Posts
    Global Posts
    938 Global Posts
    My S3 does this when I am in a bad signal area or when it is trying to auto connect to a WiFi access point.
    Quote Originally Posted by crester View Post
    No.
  8. #8
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    try installing a temperature widget m8. id say anythin over 50°c is dodgy on the s3
  9. #9
    jc86's Avatar
    Posts
    I had this happen to me once. You might have something running in the background. Try clearing tasks and/or RAM. I was doing something on my phone, put it in my pocket and started having dinner. Few minutes later my pocket felt really hot. The battery drained from 30% to ~15% in maybe an hour. I cleared my tasks and cleared the RAM which seem to have helped.
  10. #10
    tdoom15's Avatar
    Posts
    Global Posts
    105 Global Posts
    I've had this happen to me once as well. I tried to send a text and email and for some reason it wasn't sending, so it kept trying to resend in vain. The phone got fairly hot and lost a like 10-15% battery in maybe 30 mins.
  11. Thread Author  Thread Author    #11
    Quote Originally Posted by funkylogik View Post
    Is that the name m8?
  12. Thread Author  Thread Author    #12
    Has anyone had a problem with phone getting hot while using phone you tube,etc?
  13. #13
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default
    Quote Originally Posted by One King View Post
    oops sorry i keep forgetting this is a US forum lol m8 is short for mate
    i use "battery notifier (big text)" and switch off the normal battery percentage in status bar. it puts a nicer percentage in the status bar which changes colour at set percentages and tells u time unplugged, temperature + voltage in notification pull-down
  14. #14
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    heres a screenshot of Battery Notifier..
  15. Thread Author  Thread Author    #15
    91 deg battery
  16. #16
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    celsius or farenheit lol??? soz farenheit died out years ago with tuppenys and yards in my country lol
  17. Thread Author  Thread Author    #17
    91f
    32c
  18. #18
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    cool thats cold man. think hottest my s3 has got is 45/46° my old zta blade (overclocked) used to hit 50
  19. Thread Author  Thread Author    #19
    Battery life sucks.
