- 07-25-2012, 09:58 PM
Thread Author #1
Go SMS Pro Double Notification (same app)
Hey there! Just switched over from being a long time iPhone user and I am having some troubles with Go SMS Pro.
I enabled the group messaging and MMS options (group messaging is working fine), but whenever someone in the group thread replies, I get a notification that they have replied and that reply contains nothing. Not but 1 to 2 seconds later I get another notification from the group thread and it shows up there. I have disabled notifications from the default messaging app and all that fun stuff. I have no idea on why this is happening and I am turning to you guys for some help.
Thanks so much!
- Colin - 07-26-2012, 01:00 AM #2
Re: Go SMS Pro Double Notification (same app)
im a long term go sms user but ive never used group messaging. what is it?
- 07-26-2012, 08:34 AM
Thread Author #3
- 07-26-2012, 08:38 AM #4
I love GO SMS Pro! Much better than the stock messaging app. However I do not have this issue. Is it everytime you get an SMS?
Also have you disabled the WHOLE stock messaging app? So that its not running at all?
Menu Button > App Management > Scroll to the stock messaging app > Disable...
That might fix it. Let me know if this helps at all.HTC One (ATT GSM)
Palm Pre- > HTC Evo 3D > HTC One X (White) > Samsung Galaxy S3 (White) > HTC One (Silver)
If any of my posts help you don't forget to thank/like it!! - 07-26-2012, 09:50 AM
Thread Author #5
I have the stock messaging application disabled already. If the screenshot attachment works, it comes up with this before notifying me in the group thread itself. If it doesn't work, it's just a picture of the notification I get before it moves the message into the group thread. It's just a blank text that contains nothing.
If it helps any, it's converting messages to MMS before it sends. - 07-26-2012, 09:52 AM
Thread Author #6
- 07-26-2012, 01:38 PM #7
- 07-26-2012, 02:02 PM
Thread Author #8
It's doing it for MMS mainly. For normal SMS texts or conversations with one other person work fine, as I only get one notification for those. It's just the group ones that I get this event for. I have a slight feeling that it is doing this because of MMS, but I'm not positive.
- 07-26-2012, 06:19 PM
Thread Author #9
- 07-29-2012, 11:56 AM
Thread Author #10
- 07-30-2012, 01:31 AM #11
I too have the same problem. It's the delay that sucks. Usually I only get that when people send me pictures though. Definitely weird but not that bad. What drives me nuts is when people send me texts and pics in same message and I get them in the stock app as a slide show.
- 09-09-2012, 09:21 PM #12
Yup, have this same issue. It's funny, because this basically only happens because my friends all have iPhones, and the group MMS is an iPhone only thing and makes it a pain in the **** for us Android folks!
- 09-27-2012, 07:35 PM #13
Actually MMS is the work around to get the group text to work. It works fine for me and very quick. I actually turned off pop-up notification because I don't like them in general but the main problem for me is that I get alerted twice. Cause the first alert is getting the text from the individual person then the second is that message getting moved to the group.
LG TP 1100 | Sanyo SCP-5150 | LG PM-325 | Nokia 1100 | Motorola v557 | Treo 755p | HTC EVO 4G | Samsung Galaxy S II Epic 4G Touch | Galaxy S3
Sprint customer since 2000
- 11-06-2012, 10:03 AM #14
I just switched to Gosms from Handcent (again) and I'm seeing this issue as well. It is only doing this when group texts come in. I suspect it is how Gosms is recognizing the texts and them moving them to the group, but it's annoying to get two separate notifications. I did not have this issue with Handcent group texts, but I was tired of their interface. Hope it gets addressed soon!
- 03-11-2013, 10:24 AM #15
- 03-11-2013, 10:38 AM #16
I only used Go SMS briefly, but I seem to recall that you were supposed to disable the OEM app, or maybe there was an option in Go SMS to disable the stock app. I dont' remember for sure, but check the instructions for Go SMS.
PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
If I've helped you, please press the Thanks button.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 03-11-2013, 04:54 PM #17
Reply
