UPDATE/CONFIRMED:
The plummet is back.
After 10 days of plummet-free use with LTE disabled, it has returned after less than 48 hours uptime following my re-enabling of LTE.
For me, I am quite convinced that some LTE bug - perhaps with switching back and forth to HSPA+ - is causing the plummet. Unless some very knowledgeable devs join this discussion and help to find the root cause, I only see two options to avoid this problem:
1) Disable LTE and live with HSPA+ speeds
2) Wait for an OTA update with a fix, assuming Samsung/AT&T know about it
Personally I am sick and tired of wasting my time diagnosing this. I have lost time and enjoyment of my device trying to keep a stable testing environment. I now know the general cause and solution and am satisfied with that.
Thanks to anyone and everyone who helped.
Again, here is the link to my method for disabling LTE:
http://forums.androidcentral.com/t-...isable-lte-t-s3-you-can-disable-hspa-too.html
It's unfortunate that using HSPA+ only also disables 2G, but that's not really a problem for me in Miami.
Anyone who can help diagnose the cause of this would be my hero. Please read carefully the evidence I already have.
Scenario:
Battery life is great for awhile and then suddenly it will start plummeting for no good reason. It will continue to do so, even if the screen is off and the phone is unused with all tasks closed. It will not stop dropping fast unless I reboot it. Then battery life returns to normal/excellent..a day or so later it starts dropping fast again.
Things I've tried:
-Factory reset - reinstall only most common apps
-Exchanged the device at AT&T - same result
-Monitored with GSAM (Badass) Battery Monitor and Better Battery Stats. No culprit found.
Important notes:
-As per attached screenshot*, I have tested ways to stop the drain without a reboot. Turning off wifi does nothing. Turning off mobile data does nothing. Turning off the radio (airplane mode) is the only way to stop it - but once I turn airplane mode off, it continues to drop quickly. Only a reboot is a working temporary fix.
-The phone itself is reporting the "cell standby" as the major culprit. I am not sure if this is inflated due to the known bug in reporting that data.
-There is something quirky with the "mobile network signal" bar - I am in Miami where signal is strong almost everywhere. The steep decline occurs even at my apartment where I always have 4 or 5 bars of LTE signal. I am almost never in any area where there is no signal, despite what the line indicates.
Attached screenshots:
1 & 2) good battery life followed by a sudden and steep decline
3) the subsequent "test" listed in note # 1 above with the resulting plateau achieved by turning on airplane mode with the drop continuing when airplane mode was disabled
4 & 5) I then charged the device to full overnight and unplugged it in the morning. I let it sit unused for about 2 hours and the battery dropped 25%.
6 & 7) these screenshots are from normal excellent battery life scenario where the "plummeting" battery did not occur
Thank you so much for any help.
