This issue isn't about poor battery performance. There is a sudden rapid decrease in battery % that gets triggered by something, but no one can figure out what that trigger is. I think what we can all agree on is that it always happens in an LTE area when Wifi is turned on & connected. On the surface, this doesn't make sense. If you connect to wifi, the phone will automatically turn off mobile data. But this plummet doesn't happen in non-LTE areas. The phone should be ignoring the LTE, but it only happens when LTE is present. So I believe that some process kicks in and the phone gets confused on whether it should be using Wifi or LTE. I think it's trying to access/find the LTE tower, but since mobile data is turned off, it won't find it...so it just sits there spinning away looking for something it will never find...draining the battery in the process.
The problem is not with the battery, as I've had it happen with both my batteries (one of which was brand new). There are a number of screenshots in this thread that will show you what the plummet looks like. It's got to be a glitch of some sort. Another thing to point out is that when the plummet does not happen, either screen or standby is the #1 battery user. But when the plummet occurs, it's the Android System (kernel). So the kernel is freaking out about something related to LTE + WiFi. Other than that, no one can figure out what causes it.
Mine started suddenly after about 3 months of flawless operation. I'm going to try switching my lock screen from PIN back to Pattern and see if that makes a difference.
