This is to confirm the LTE battery drain issue. With LTE enabled, some phones (mine) will discharge in the standby mode, fast enough to raise the temperature of the case so that it is warm to the touch.
I searched and searched and tried everything offered up on the internet everywhere, but it wasn't until I found this thread that I finally got to the bottom of the battery drain issue.
An OS update was pushed over-the-air a few days ago, and presto, battery drain issue came back. Now I've got this thread bookmarked.
Here's how to disable LTE:
1) With phone on, take off back cover and press your SIM card so it releases from the spring. It won't come all the way out as it's blocked by the battery. This seems fine - I didn't bother trying to force it out as I didn't want to break anything...
2) Once you see the message that the SIM card is removed, go to the dialer and dial *#2263#
3) You should see a menu with band selections. The current setting is "Automatic". If you switch to "GSM All", you will be EDGE (2G). If you switch to "WCDMA All", you will be on HSPA+ (3G, though AT&T and others call it 4G).
4) Press the SIM card back into place until it clicks. For whatever reason the phone will not recognize it until you reboot. Upon reboot you should see your new setting in effect.
