DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for Samsung Galaxy S3!
Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By alan sh
    alan sh's Avatar
    Posts
    Global Posts
    903 Global Posts
    Default How do I unmount an external USB memory stick?
    I have a cable with a micro SD connector on one end and a USB socket on the other. I can plug in my USB memory stick (64gb) and see the contents/play/copy etc. All works fine.
    But, when I remove it, I get a message that I didn't unmount the stick and I may have damaged the contents. So, is there a way of unmounting it?
    Thanks
    Alan
  2. Thread Author  Thread Author    #2
    alan sh's Avatar
    Posts
    Global Posts
    903 Global Posts
    Default Re: How do I unmount an external USB memory stick?
    Found my own answer - you do it from the notification bar.
    Alan
    Thanked by 3:
    barryl85 likes this.
