Results 1 to 2 of 2
    Default Volume Control Question
    Is there a way to link all the volumes to be controlled by the volume rocker, like a master control, how it was with GB? I hate lowering the ring volume to go to bed only to be woken up by a loud txt message...
  2. #2
    Default Re: Volume Control Question
    I use an app called audiomanager to create custom profiles. This allows me to have a single profile that adjust each volume control to exactly how I want it. You could also use something like 'Tasker' to do this as well
