DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for Samsung Galaxy S3!
Results 1 to 8 of 8
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default quick battery use question
    what does Media Server mean? (3rd down on this screenshot)
    http://db.tt/Jw2isNDX
  2. Thread Author  Thread Author    #2
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default Re: quick battery use question
    grr stupid link
  3. #3
    walcolm's Avatar
    Posts
    Global Posts
    747 Global Posts
    Default
    Ur pic link is requesting a dropbox log in
    Sent from my GT-I9300 using Android Central Forums
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default
    Quote Originally Posted by walcolm View Post
    hmm. thanks for telling me that man. is that normal for dropbox links to do that?
  5. #5
    walcolm's Avatar
    Posts
    Global Posts
    747 Global Posts
    Default
    Not if you copied the link correctly. Folks who don't use dropbox should be able to view dropbox link to picture and videos if you copy it right
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    cheers man. dont know what i did wrong. i just tapped "share" on the db app and copied to clipboard like i usualy do...
  7. #7
    The mediaserver service is any native or application which uses or streams your media which can be music, videos, even apps like iMeem, streamfurious, Pandora, TuneWiki, You Tube, and don't forget apps that have built in media playing/streaming.. Podcasts players, etc... For me it's high only when I use my podcast player or Google Music to stream on the train to work in the morning...
  8. Thread Author  Thread Author    #8
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default
    Quote Originally Posted by r3ddawn View Post
    ah right thanks. im guessin its been youtube then
