You mean rooted? TiBU only works if you're rooted.
I suggest you don't restore backups from one device to another, regardless if they're the same model or not. This can often cause force closes and issues within apps/settings.
Basically, it's better to restore everything from scratch and start with a clean plate. This stuff happens, and by the time you get the work around ready to go you could have already manually corrected your settings.
Sent from my SCH-I535 using Android Central Forums
