Results 1 to 6 of 6
- 08-15-2012, 07:14 PM
Thread Author #1
Help with a bug: unlock screen partially shown
Having this problem on a daily basis and wondering anyone experiences it.
When unlocking and about to input the 4 digit pin, the the screen is partially shown so I can't access the entire numbers. Will post a screenshot soon. Edit can't upload photo directly from s3 to forum.
Only way to fix is to either restart device or remove the pin unlock security.Last edited by hp10BII; 08-15-2012 at 07:27 PM.
- 08-16-2012, 07:47 PM
Thread Author #2
- 08-17-2012, 12:00 AM #3
- 08-17-2012, 07:41 AM #4
- 08-17-2012, 03:29 PM
Thread Author #5
- 08-24-2012, 10:17 AM #6
Re: Help with a bug: unlock screen partially shown
One of my end-users is having this same exact issue, but on a completely different phone (Casio G'Zone Commando) and obviously a different OS (Android 2.3.3). Did you ever find anything that helped you resolve it? I had the carrier replace the phone because it had just received an OTA update when the problem showed up. Now the refurb is doing the same thing! Any help would be awesome.
Reply
