whenever its in my pocket or sometimes i am just surprised when i turn it on its on silent mode...
is there a short cut to silent mode with the power button that is making it do that in my pocket?
Printable View
You can go to silent mode by pressing down on the volume button or by using the pull down notification toggle. Not sure how you are doing it by accident. Is your phone in a case? Maybe the button is being pressed by the case.
Sent from my Verizon Galaxy S3.
yeah im having the same problem sometimes even wn the S3 is in my hand and i didnt press anything it goes on silent by itself, any advise?
Do you have a case? I had once case that I found was sometimes pressing on the volume button and lowering my volume all the way to silent.
Dear Shady,
The issue may be caused by AVG Antivirus... if you have it installed try uninstalling & check...
Don't know why people are still using an anti virus app, I used it for about 2 months, didn't really find anything, pretty much a waste of timeQuote:
Originally Posted by Prof Said [Only registered and activated users can see links. Click Here To Register...]
Sent from my SPH-L710 running Liquid Smooth RC2 4.2.2
