Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By meyerweb
    bulls96's Avatar
    Posts
    Global Posts
    2,594 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default S3 spontaneously goes to silent mode
    whenever its in my pocket or sometimes i am just surprised when i turn it on its on silent mode...
    is there a short cut to silent mode with the power button that is making it do that in my pocket?
  2. #2
    broadwayblues's Avatar
    Posts
    Global Posts
    516 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Rooted, Unlocked
    Default
    You can go to silent mode by pressing down on the volume button or by using the pull down notification toggle. Not sure how you are doing it by accident. Is your phone in a case? Maybe the button is being pressed by the case.
    Sent from my Verizon Galaxy S3.
  3. #3
    Shadi Hisham's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: S3 spontaneously goes to silent mode
    yeah im having the same problem sometimes even wn the S3 is in my hand and i didnt press anything it goes on silent by itself, any advise?
  4. #4
    meyerweb's Avatar
    Posts
    Global Posts
    10,320 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do you have a case? I had once case that I found was sometimes pressing on the volume button and lowering my volume all the way to silent.
    crester likes this.
  5. #5
    Prof Said's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Dear Shady,
    The issue may be caused by AVG Antivirus... if you have it installed try uninstalling & check...
  6. #6
    Soundtrack to Chaos's Avatar
    Banned
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Prof Said View Post
    Dear Shady,
    Don't know why people are still using an anti virus app, I used it for about 2 months, didn't really find anything, pretty much a waste of time
    Sent from my SPH-L710 running Liquid Smooth RC2 4.2.2
  7. #7
    Rusty tuttle's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have a Samsung T105g basic phone with case. When I bump or put the phone in my pocket, the phone will reset back to silent and vibrate and lowest value.
    I continually have to reset the phone back to audible and high volume. This is very frustrating help!
  8. #8
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sounds like the case is pressing on the Volume Down rocker.
    What happens if you take the case off?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
  9. #9
    Jim Cooper's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am also having the same problem; since day one, am using no exterior case on my S3. T-Mobile store said that my apps were using too much memory & to go into 'Task Master' and do a memory dump... Well it made no difference.
    I had occasion to talk to a new 'S4' user; he admitted to having the same problem. Go figure.
    I don't like the idea of having to constantly check the settings on my phone.
  10. #10
    nmbeg's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am having the same issue with my new Galaxy Note 3. No case. The phone is always "off" when i put it into my pocket, and randomly when I look at it later it will be in silent mode.
  11. #11
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    To be sure it's not a 3rd party app causing the problem you can try booting into Safe mode (http://support.verizonwireless.com/s...ase.html/59242) to see if the problem still occurs.
    If you have Motion enabled, be sure that "Palm touch to mute/pause" is disabled in Settings -> (My Device) -> Motion.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
  12. #12
    Blapsie's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs up Re: S3 spontaneously goes to silent mode
    I immediately deleted and uninstalled the AVG antivirus and guess what??? It worked!!! Thanx so much!
