- 08-20-2012, 10:48 AM
Thread Author #1
iSyncr using internal SD card vs external SD card for music
I am using iSyncr to sync my music to my phone. I just realized that although iSyncr says it is syncing to my SD card it is syncing to my INTERNAL SD card not my external SD card. I don't see an option to sync music to my external SD card which is where I want it to go. Does anyone have any suggestions?
- 08-20-2012, 04:53 PM #2
- 08-20-2012, 05:01 PM
Thread Author #3
- 08-20-2012, 05:03 PM #4
Re: iSyncr using internal SD card vs external SD card for music
yeah the internal storage on s3 is called SD and the external is called EXT SD but i know nothing about iSyncr mate sorry
- 08-20-2012, 05:04 PM #5
you could just sync to the internal sd and then move the tunes to ext sd using MyFiles
- 08-20-2012, 05:08 PM #6
When you connect your phone or open iSyncr a pop up let's you choose to which drive you want to sync.
What OS are you running in your computer?
Sent from my SGH-I777 using Android Central Forums
Android: Resistance is Futile!.
- 08-20-2012, 06:51 PM #7
In iSyncr:
Settings -> Default storage -> SD card.
Your choices are internal storage or SD card with iSyncr. Mine is stored on the ext SD. I have verified this using Astro and Kies.Samsung Galaxy S4 - AT&T
Samsung Galaxy Note 10.1 LTE - VZ
Galaxy Note 8
Apple iPad3 - 64GB LTEThanked by: - 08-20-2012, 07:31 PM
Thread Author #8
Interesting. That's the way mine is set up but it goes to the virtual SD card. I'm using iSyncr wifi. It was actually Astro that made me aware of the issue. I was checking available space on my SD card and realized I had way too much....
Sent from my SCH-I535 using Android Central Forums - 08-20-2012, 10:53 PM #9
Galaxy Note 8
Apple iPad3 - 64GB LTE - 08-21-2012, 08:53 AM #10
- 08-21-2012, 11:34 AM #11
- 08-21-2012, 01:22 PM #12
- 08-21-2012, 04:18 PM
Thread Author #13
- 08-21-2012, 08:37 PM #14
- 08-21-2012, 09:30 PM
Thread Author #15
- 09-22-2012, 11:12 PM #16
I am actually having the same problem and with the help from Astro File Manager confirmed it's writing to the internal SD (16GB) vs. External SD (32GB). My thought is that this might be a setting on the HTC Rezound phone rather than the iSyncr application but hoped you had an answer to your note and posting.
- 09-23-2012, 07:25 AM
Thread Author #17
- 09-23-2012, 02:00 PM #18
I am following up to let you know this was not an issue with iSyncr, rather an issue with the SD external card. The best I can figure is that when verizon downloaded the new andriod OS (4.0) it tried to unencrypt the SD card; which it did but made the card unusable even though it was mounted.
My fix was to removed encryption then shutdown and pull the SD card out and reinsert it. Once the phone was restarted it formatted the SD card.
Now I am able to redirect music to the external SD card. - 09-28-2012, 11:54 AM #19
I am having the same problem In fact Isyncr doesn't even see any sd cards (/mnt/sdcar or /mnt/extsd)
I wrote to them and still wating for a response..
Here is what they said:
Hi,
Shoot. You're running the latest version (4.0.1), right? Which Android device are you using?
Cheers,
Hexar
Want to wirelessly sync files and folders between your computer and Android? Check out Cheetah Sync! https://market.android.com/details?id=com.jrtstudio.SyncFolders
Bored? Check out our dev blog! http://blog.jrtstudio.com/
Sent: Tuesday, September 25, 2012 7:50 AM
To: 'Hexar Anderson'
Subject: RE: Cannot set default /mnt/extsd
No. See attached.
From: Hexar Anderson [Sent: September 25, 2012 1:19 AM
Hi,
So if you go into Tools -> Settings -> WiFi Policies, do you see an option at the top called Default Storage or no?
Cheers,
Hexar
Want to wirelessly sync files and folders between your computer and Androd? Check out Cheetah Sync! https://market.android.com/details?id=com.jrtstudio.SyncFolders
Sent: Monday, September 24, 2012 8:16 PM
To: iSyncrWiFi@jrtstudio.com
Subject: Cannot set default /mnt/extsd
I have your app on my phone and tablet (I am a paid customer)
For some reason, the available /mnt/extsd (or any other sd media) is not being shown as an option to set the default sync to option.
I have root on the tablet.
The only way I can sync is via USB and running isync.exe from the extsd drive from my windows pc.
Do you have any suggestions? I would prefer to do a scheduled Wi-Fi sync on the tablet instead of the manual process.
Thanks for such a great product! - 09-28-2012, 07:44 PM #20GT-I9300, UK
- 09-30-2012, 05:22 AM #21
Thanks, that was the hint I needed. :-)
First I just tried to insert the complete path in Syncr at
Settings -> WiFi Sync -> Sync Folder
But the path I entered /mnt/extEdCard/media/music was saved as mntextEdCardmediamusic. Unusable of course.
Considering your hint I went to
Settings -> WiFi Policies -> Default Storage
and there I could select "Internal Memory" or "SD Card". I choosed "SD card".
Then I went back to
and I just inserted "syncr".
Now my music is synced to the SD card. Not exactly into that folder I would like to (media/music), but better than nothing.
Reply
