Results 1 to 10 of 10
    AlexJH1992's Avatar
    Posts
    Global Posts
    52 Global Posts
    Default Battery performance??
    I charge my phone overnight (8 hours) every night, I wake up at 6am and travel to work and my phone stays locked up at work until I leave around 6pm, battery is still on 88 percent. I then will use the phone constantly and the battery will die around 8pm, is that right? What's everybody else's battery performance??
    Thanks
    Sent from my GT-I9300 using Android Central Forums
  2. #2
    Default
    That sounds pretty quick to drop 88%. Mines about to die but I'm 20 hours off battery and 4 hours and 45 minutes of screen time. Were you playing battery heavy games for those 2 hours?
    Sent from my Samsung Galaxy S3
    AlexJH1992's Avatar
    Posts
    Global Posts
    52 Global Posts
    Default
    I usually go on twitter for a while and send a few texts and a few 10 minute calls, my battery seems to drain really quick
  4. #4
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default Re: Battery performance??
    something sounds very wrong there man. have u checked what apps are using a lot off battery after work? how high is your screen brightness?
  5. #5
    Tkbredx's Avatar
    Posts
    Global Posts
    1,839 Global Posts
    ROM
    TeamSonicFreeGS3 v9.1
    Default
    Quote Originally Posted by funkylogik View Post
    the screen truly is a hog. I wonder which uses more power LCD or amoled.
    With brightness on 100 and heavy use you could very easily die from 3 hours of use
  6. #6
    Install the 'Easy Battery Saver'. You can save the battery life of your device upto 50%.
  7. #7
    I take mine off charge about 6:30 am and check fb and flipboard emails etc for about 60 minutes through the day and send a few txts etc.I may make a 30 minute call on the way home. On a good day I have 60% left at 9pm and on a bad day like today with a few phone calls its at 36%
  8. #8
    Here is some good advice dude. When you have an available wifi connection, use that instead of 4G. Your mobile connection uses up way more battery than wifi. I had my phone locked for 2 hours and it used up 2% only on wifi. I should check facebook and email for like 5 mins too. Also try disabling apps you dont use in Application manager. Keep Bluetooth off if you have it on. Heck, try disabling some transition effects in the developers menu.
  9. #9
    Something that you can do... Download GSM Battery Monitor. It gives you a better breakdown of what is eating away at your battery. Instead of just saying "Android System" like the stock battery monitor, when you GSM will show what apps in Android System are consuming battery as well as percentages of everything else.
  10. #10
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default
    Quote Originally Posted by Tkbredx View Post
    it depends what colours youre viewing. amoled uses no power to display black, its not backlit, so in general it should use less power. save a lot of power on sites like this by using the "invert colours" toggle. its in widgets screen is always the biggest drain though and surface area of the s3 screen is pretty big
