Results 1 to 8 of 8
    infusehelp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default HELP! Data usage alert won't go away!
    And it's annoying the crap out of me! I have zero clue how to get rid of it....i've tried everything....please help!
  2. #2
    g1toevo678's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Settings>Data Usage. Turn off alerts altogether or increase alert level on the graph.
    This is on the Verizon version of the S3 so might be different on others but should be something similar.
    Sent from my SCH-I535 using Tapatalk 2
  3. #3
    standog100's Avatar
    Posts
    Global Posts
    52 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    It happened to me...either increase the data level or uncheck data limit or just wait for the preset date and it will renew itself...
    Sent from my GT-I9300 using Android Central Forums
  4. #4
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    Default Re: HELP! Data usage alert won't go away!
    yeah its same on all s3s.
    friendly tip: take some time to explore all the settings
    infusehelp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thanks guys!
    wait...it still won't go away.....annoying!
    infusehelp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by standog100 View Post
    will it eventually go away?
  7. #7
    534n's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Screenshot of the monitoring app please
  8. #8
    carol19013's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wink Re: HELP! Data usage alert won't go away!
    Raise the limit bar to the maximum and it will go away. Worked for me.
