Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Like Tree2Likes
    Default [Q] How Much Battery Percentage Is Android OS Using On Your S3?
    *To check go to Settings > Battery
    Mine is at 39%. I thought that was rather high. I Odin'd back to stock and it's still locked at 39%. I feel like it used to be around 11% or so.
    Whats is everyone else's?
  2. #2
    Ricky Babalu's Avatar
    BEACH BUM
    Posts
    ROM
    Stock : Rooted, Unlocked
    Default Re: [Q] How Much Battery Percentage Is Android OS Using On Your S
    Android System: 8%
    Android OS: 6%
  3. #3
    Quote Originally Posted by jaj6503 View Post
    How is your battery life? I think 39% is a little high.
  4. #4
    *nevermind*
  5. #5
    Default
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
    Attached Thumbnails Attached Thumbnails [Q] How Much Battery Percentage Is Android OS Using On Your S3?-uploadfromtaptalk1346442669088.jpg
    Quote Originally Posted by mak916 View Post
    Pretty crappy ATM. I'm going to freeze some bloat and see if that helps.
  7. #7
    Default
    Mine is 6% and 11%. Not sure if the bloatware is using the Android System or Android OS services. I am sure the bloatware usually have their own app in the battery usage list. Try to check syncing account. If you have many account that kept syncing real time, maybe that is the problem, it can go up that high. I agree with the above poster, it is rather high for the Android OS to use that much.
    Sent from my SGH-T999 using Android Central Forums
  8. #8
    Tkbredx's Avatar
    Posts
    Global Posts
    1,839 Global Posts
    ROM
    TeamSonicFreeGS3 v9.1
    Default
    Os: 4%
    System: 6%
  9. #9
    Default
    Mine is running at 6% right now. Something is wrong with your phone in my opinion.
    Sent from my Blue 32 GS3.
  10. #10
    Default
    Mine is over 50percent consistently, as high as 65.
    Sent from my Samsung Galaxy S3
  11. Thread Author  Thread Author    #11
    Default
    Hence the reason this thread exists...
    I flashed the stock kernel than restored a backup. It's running at 12% now. I can live with this.
    Sent from my rooted/modded/stock Samsung Galaxy S3 using Android Central Forums
    Attached Thumbnails Attached Thumbnails [Q] How Much Battery Percentage Is Android OS Using On Your S3?-uploadfromtaptalk1346450832209.jpg
  12. #12
    Fonz0's Avatar
    Posts
    Global Posts
    199 Global Posts
    Default
    Stock kernel here also. Running at 12% and 5 %
  13. #13
    Default
    Is this something I should take the phone back for???
  14. #14
    bassmig's Avatar
    Posts
    Global Posts
    333 Global Posts
    I am sitting at 17% and 6%. My biggest issue is Cell standby which is typically between 30% and 60%.
  15. #15
    Default
    Mine is always extremely high.
    I've narrowed it down to Alarm Manager that is in the Android OS.
    I've uploaded screen shots to show it in BetterBatteryStats
    I also noticed that my phone is constantly awake. It never sleeps according to battery stats.
    It looks like lite flow app is showing 50k wake locks. Which is insane. Not sure if that's what causing the bad battery life though.
    Sent from my SCH-I535 using Android Central Forums
    Attached Thumbnails Attached Thumbnails [Q] How Much Battery Percentage Is Android OS Using On Your S3?-uploadfromtaptalk1346466861808.jpg   [Q] How Much Battery Percentage Is Android OS Using On Your S3?-uploadfromtaptalk1346466875842.jpg
  16. #16
    Android OS 12%
    Android System 10%
    On battery for 14hr with a battery at 37%.
    Rooted running stock ROM and locked boot loader.
    Samsung Galaxy S4 - AT&T
    Samsung Galaxy Note 10.1 LTE - VZ
  17. Thread Author  Thread Author    #17
    Default
    Quote Originally Posted by SteveISU View Post
    Your device is fully stock??
  18. #18
    Default
    Yes it is.
  19. Thread Author  Thread Author    #19
    Default
    You could try flashing the stock kernel using Odin and see if that makes a difference. No harm in trying and you don't need root to do so. If you want to try/need help let me know.
  20. #20
    My battery is at 63% after 17h 8m 40s on battery with AOS at 7% usage.
    Stock rooted/unlocked, auto brightness, all input feedback disabled, TouchWiz disabled, only data services enabled are LTE/WiFi. ADW launcher with BW 4x2 super clock and power toggles widgets.
  21. #21
    Android 4% System 7%, Standby 36%, Screen 32%
    Stock with Chrome and Dolphin, power saving mode, auto-brightness OFF, Juice Defender, WiFi when at home
    1d 3h 37m 22s , 47% charge remaining
  22. #22
    Default Re: [Q] How Much Battery Percentage Is Android OS Using On Your S3?
    I just got the phone. My android OS has been topping the list at 50%-60%.
    Rooted with stock rom.
    Today I deleted a lot of the bloatware apps and services. Enabled Power Saving feature.
    Ill give it a day or two, see if that made any difference.
    edit: Correction, Android System is the one using up all the %.
  23. #23
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    its a percentage so it depends what youve been doing. ive had screen on browsing since unplugging and android os has used 6%
    obv if your screen is off since unplugging, the percentage will be higher?
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or crazy) guess
    GT-I9300, UK
  24. #24
    So I bought this phone 2 days ago. Previous to this I had an LG Optimus, which I could get 2 days worth of battery before needing a charge. So I used that as a benchmark.
    Arrive at work this morning and my battery is already in the high 80s, with it draining fast. Like 15% per hour. I decided to check the battery stats and showed that Android OS was using way too much CPU for the little time I used the phone.
    I downloaded betterbatterystats to see what was happening. Enabled Power Saver feature with CPU throttling only.
    Started to read around and a lot of people were complaining about services like gtalk, facebook, etc. Deleted a lot of bloat services that are included with the stock rom. This seems to have done it.
    The battery curve was going down hill pretty fast. Android System using 50%+ of the CPU. (this is relative to all other services).
    Now the battery isnt draining as fast as it was this morning, and CPU usage is starting to level out.
    Ill give it a few days see how it works out. This morning this thing was eating 15% an hour. Now Its just doing about 5% an hour.
    funkylogik likes this.
  25. #25
    I had the same battery drain last week. Android OS was always around 60% and I would have to charge my phone three times a day.
    I noticed it was a couple of apps that were trying to run in the background all the time, cat sounds soundboard and crackle. I deleted those two apps, allowed my battery to die completely and shut off, and charged my phone all night.
    The next morning the phone turned on properly and the Android OS was back to normal and I go the entire day on a single charge.
    That was a week ago. So far, so good (knocking on wood!!)
    riderrick65 likes this.
