- 09-06-2012, 10:05 PM
Thread Author #1
LED Backlight "Deadspots"
This is not really a problem but more of a curiosity. When the screen is on, but completely black/blank (i.e. app loading) there are several very dark spots distributed throughout the screen where the LED backlight appears to be off. This has absolutely no effect on images on the screen though and is not noticeable when the screen is displaying ANYTHING other than a solid black.
Does anyone else see this on their phone?
EDIT: Also only visible when on lowest brightness.Last edited by 534n; 09-06-2012 at 11:11 PM.
- 09-07-2012, 06:27 AM #2
- 09-07-2012, 06:41 AM #3
Re: LED Backlight "Deadspots"
for one the LCD screen has NO backlight, black=no light.
sounds like screen "burn in". do you both have brightness at full? - 09-07-2012, 06:43 AM #4
Sounds like the dreaded screen burn in that people tried to convince me didn't exist.
Sent from my Nexus 7 using Android Central Forums - 09-07-2012, 06:57 AM #5
- 09-07-2012, 07:31 AM #6
I don't think it's screen burn in. I only have one dark spot and it's a perfect circle
- 09-07-2012, 07:37 AM #7
- 09-07-2012, 07:44 AM #8
- 09-07-2012, 08:02 AM #9
yeah im "lucky" to live in west of scotland so brightness is usualy around 10% so doubt il suffer burn in but if i get a deep scratch il be leavin ma phone on full brightness with an apple logo on the screen n sendin for replacement
Thanked by: - 09-07-2012, 08:04 AM #10
Seems like its the blotches of black dots only when screen is black on bright ness. This is certainly not screen burn it. Its the nature of amoled screens. People on xda have pointed this out on new phones. I have never seen it on mine even when I try to look for it since I only run max brightness.
- 09-07-2012, 08:50 AM
Thread Author #11
They are LED based screens and I use auto brightness and never really have it go up that high because I don't use the phone outside. It is definitely not burn-in and that does not commonly affect the LED (whatever variant) or LCD screens, and I have NEVER heard of screen burn in on a non CRT based screen. The term screen "burn in" refers to the layer of phosphorous being modified by the constant bombardment of electrons from the cannon in exactly the same spots continuously over time that it never has a chance to re-settle, thus burning a permanent "image" in the screen, which is really just areas of the phosphorous layer that have been worn in unevenly.
It is just a perfect circle near the lower left of center on the screen. And a few other small spots throughout. I think it is places that the driving voltage for the brightness is not enough to keep the LED lit and it goes dark, or just a distribution from the function of the logic controller. I am not sure what causes it but it just intrigued me the first time I noticed it. It literally has no effect other than being visible when the screen is at minimum brightness and fully blank. - 09-07-2012, 09:29 AM #12
cheers for the technical info m8, i love to learn. but aparently (think it was jerry jerry who quoted it) samsung have admitted to a problem with burn in on the s3 and recommend using low briitness (not much use to our friends in horrible sunny places lol) and dont know if its rumour but aparently theyl replace affected panels if it impaires normal use.
so would burn in only be visible with pixels at high R/G/B level and not visible with them at zero (true black)? - 09-07-2012, 09:55 AM
Thread Author #13
Honestly, I think Samsung took something that was just people complaining about something they thought they saw and then hysteria made worse and made an "issue" out of nothing so people would keep quiet. The only way an LED can burn is if too much power is fed across it so people with root brightness changers may have turned the brightness up higher than it should have or something damaged the screen outside of normal conditions.
The people that had legitimate problems seemed to arise from having the brightness up all the way and leaving the screen on for a majority of the time. While several people said this did not affect their phones, the heat, power (based on the color/contrast of the image on the screen), and other factors may have caused the LED's "backlight" capability to become reduced, lowering the sharpness between pixels and reducing the brightness possible for those pixels, thus creating the image distortion they saw.
As for one bit of interesting information that I read, the status bar is usually the only part of the phone that is not burned in by people with bright screens and images on all the time. Since the status bar is mostly black, the rest of the screen with the vibrant images becomes worn, but the user assumes the smaller portion of the screen is the damaged portion.
It looks like no one knows for a fact what causes it or how to replicate it reliably. It may just be a property of the driving voltage, switching, and material of (AM)OLED based screens. - 09-07-2012, 11:31 AM #14
This is not burn in. Burn in is a different problem.
What you're seeing is a semi common defect with Oled screens in general. On a black background in a dark room darker splotches can be seen. Just Google "black splotches Oled phone" to see examples and compare
Sent from my SCH-I535 using Tapatalk 2 - 09-07-2012, 11:55 AM #15
- 09-07-2012, 12:21 PM #16
There is leakage current always and it's not a true "far edge of space black" at that. When the screen is on and the led is black it actually is still "on" in the sense that current is flowing at a small level. It's a misconception that leds are completely off when displaying black, in theory they should be but real world it is impossible. The doping of SI is inconsistent and the properties of the substrate are not ideal.
To test this just turn your phone off in a dark room and look at the screen. Now turn it on and look while on a black screen.
Sent from my SCH-I535 using Tapatalk 2 - 09-07-2012, 12:25 PM #17
@534n: You do understand the difference between LED and OLED right? They do not function exactly the same. Yes, I do understand exactly what burn-in refers to on CRT type monitors/screens. Does the average person? Probably not. So they use the term that they know that is the closest match for what they're trying to describe. Image being permanently displayed all the time = burn in. What's probably happening with the OLED "burn-in" is that those particular areas are wearing out at a faster rate then the rest, which makes them look noticeably different than the rest. So whatever area that is appears to be burned in, when it reality it's just worn out faster. Same affect, different cause.
OLED screens of all kinds can suffer from this "blotchyness". GNEX owner's have complained about this quite a bit.Forum Rules & Guidelines -- CLICK HERE
I'm an NVIDIA Tegra Champ. Here's what that means. It means that from time to time I might receive products and/or services from NVIDIA to evaluate them and provide feedback to NVIDIA and you, our valuable members. What this does NOT mean is that my opinion will be biased. Any opinion that I express here and elsewhere are solely based on my personal preference and any relevant expertise that I may/may not have on the subject matter. - 09-07-2012, 12:58 PM
Thread Author #18
- 09-07-2012, 12:59 PM
Thread Author #19
Some dynamic displays actually do turn off the backlight/LED power completely for "deep" blacks when the display is capable of turning off parts of the screen lighting, but I believe that in the case of the dark spots on the screen, you may have something like what I had mentioned about the driving voltage differences.
- 09-07-2012, 02:24 PM #20
Ooops yeah. Sorry. I guess that's what I get for skimming LOL.
Everything that's ever been said about OLED displays is that when it's displaying black the pixel is off. So yes, it does have local dimming. Pixel perfect local dimming. What I'm thinking is that maybe the source isn't a "true" black and it's confusing the device, causing some of the pixels to display a "near black". Does that make sense at all?Forum Rules & Guidelines -- CLICK HERE
I'm an NVIDIA Tegra Champ. Here's what that means. It means that from time to time I might receive products and/or services from NVIDIA to evaluate them and provide feedback to NVIDIA and you, our valuable members. What this does NOT mean is that my opinion will be biased. Any opinion that I express here and elsewhere are solely based on my personal preference and any relevant expertise that I may/may not have on the subject matter. - 09-07-2012, 02:30 PM
Thread Author #21
You would be surprised how many people do that to my posts :P
Yes that makes sense actually, like pixel noise in a picture taken of something that is in reality uniform color, like if you take a picture of complete blackness and you get random flecks of distorted colors that are "near-blacks." So I guess the backlight is turning off in the places the image is trying to display truly black and just getting close elsewhere? It is odd since it should be truly black in a native (loading / booting) screen, but then again it could be hardware based in the pixel grid or just bad approximation - or even stranger: some type of 3D "pixel terrain" that could be modeled on a tri-axis which explains why the dark spots occur where they do due to some fault or limitation of the logic control in the display.
Electronics have minds of their own sometimes and it is fascinating. - 09-07-2012, 02:42 PM #22
It's still burn in, just not the the same kind of burn in that occurred on monochrome CRTs. Using an AMOLED display on max brightness over a period of time can result in static images on the display being permanently burned into the screen. The problem occurred with a great many Galaxy Nexus devices, and is a failing of AMOLED technology. It looks almost exactly like old school burn in, which a ghost image overlaying whatever is displayed.
Sent from my One X using Android Central Forums - 09-07-2012, 03:25 PM
Thread Author #23
It also occurred on color CRTs. Oddly, not all AMOLED based displays suffer from it, and my Nexus was on max brightness for pretty much as long as I owned it and never had an issue.
The burn in of OLED is not the same as old school burn in because it is not image retention that is the issue, it is more pixel degradation, loss of brightness, and loss of color change speed/capability. The impression of a burned in images comes from the less bright or duller color from the pixels in the commonly displayed image pixel area.
Other things that can damage OLED screens are UV light, certain lasers, moisture, and decay. - 09-07-2012, 04:25 PM #24
- 09-07-2012, 04:43 PM
Thread Author #25
Actually, those images quite accurately illustrate the difference that I am talking about. The CRT shows you detailed images of what was burned in, quite literally.
The OLED screen just shows dim/dark spots where the text/icons were. It is not a "burn in" so much as a "burn out."
And the words image retention mean that the display is retaining the images, not losing the capacity to display new ones. The CRT monitor has a retained image physically burned into a layer on the screen. The OLED display just lacks the brightness in those frequently updated pixel areas. There is no retained image there.
While an interesting divergence into a different topic, this is also not what I was originally describing seeing.
Reply
[/URL]
[/URL]
