- 09-07-2012, 09:47 AM
Thread Author #1
Gsam battery monitor
Is anyone using this app? I was fine with just he battery % until my phone was awake while my screen was off. This app tells you about all power consumption based on app.
It also has a nice set of icons for your notification area and a nice widget. I currently have the ICS style icon. Anyway I think it's an awesome app and I'm trying to support the dev. There is a free version that you can try before you buy. - 09-07-2012, 09:57 AM #2
Re: Gsam battery monitor
i use it but im not sure how accurate the average battery life thing is. yday i got 12.5 hours just through normal use coz i was out but at home i use it heavily, browsing etc yet gsam says my average batt life is 13.5
hours so i take it with pinch of salt lol. really good app though. i might try a paid app called Better Battery Stats or somethin along those lines, aparently its pretty good and shouldnt be too hard to find for free
- 09-07-2012, 09:58 AM #3
- 09-07-2012, 09:59 AM #4
....oops is gsam a paid app?
i must have got it in a way thats frowned upon on here :/ - 09-07-2012, 10:37 AM
Thread Author #5
They have a free version as well as paid.
I don't really worry about the average battery life. I just look at what apps are keeping the phone awake. - 09-07-2012, 12:12 PM
Thread Author #6
Does anyone prefer the stock battery % vs any other battery monitor
- 09-07-2012, 12:13 PM #7
cool. i use a mix of both tbh mate
..trouble with stock is it resets itself when u plug in above 90% or somethin
- 09-07-2012, 12:14 PM #8
- 09-07-2012, 12:26 PM
Thread Author #9
Not really. It's kind of a ballpark. It has average battery life but it also has battery life remaining based on the last x minutes (15, 30, or 60) which is what I go off.
- 09-07-2012, 01:00 PM
Thread Author #10
The only issue I found is the information in the notification bar doesn't update frequently. Sobif you pull the bar down it will say you have 14:53 left but when you open the app it says 21:25 left.
- 09-07-2012, 04:40 PM #11
I like it. Works pretty good.
- 09-07-2012, 05:57 PM
Thread Author #12
Yeah it works well. I just don't like the fact that the notification doesn't update.
- 09-08-2012, 12:22 PM
Thread Author #13
The only thing I don't like is the notification icon is on the left side instead of with the rest of the system info. But other than that it's perfect.
- 09-08-2012, 01:11 PM #14
I love the app, the widget however is horrible. Doesn't work
On my Samsung galaxy s3 running android 4.0
Because unlike ios, i keep my apps in app drawers, and not in infinite cluttered homescreensAndroid is a tune up sports car with custom interior, sound system, and IOS is a stock model benz
I use Android, because unlike IOS, i keep my apps in app drawers, and not infinitely cluttered homescreens - 09-08-2012, 03:30 PM #15
- 09-09-2012, 02:23 PM
Thread Author #16
I've only just bought the app. And it says that the average time left should get more accurate over time. Has anyone found that is the case?
Also what theme do you use? I am torn between the big circle and the ICS monochromeLast edited by johnnyshinta; 09-09-2012 at 05:57 PM.
- 09-10-2012, 11:06 AM #17
- 09-10-2012, 01:02 PM
Thread Author #18
Yeah it says my average is 1 day 4 hours. But the FAQ says it learns constantly and gets better after each charge. If you installed it on the weekend like I did than it would make sense for it to really high. I didn't use my phone very much at all. But during the week I'm on it all the time. So we'll see if it evens out.
- 09-10-2012, 01:37 PM #19
- 09-10-2012, 02:23 PM #20
I use it and dig it so far. I mainly use it to see where my battery drain is coming from since the stock battery app doesn't accurately tell you what's eating your battery. I don't use the widget, so no ideas on that. I have been using it for a couple of weeks and think that it has gotten more accurate on how long I have remaining and avg life.
- 09-10-2012, 02:49 PM
Thread Author #21
Has anyone turned off the scaling time estimate. The % left after last 15 minutes.
- 09-16-2012, 08:29 PM #22
Widget seems to be working after the new update
I use Android, because unlike IOS, i keep my apps in app drawers, and not infinitely cluttered homescreens - 09-16-2012, 08:32 PM #23
New ui as well
I use Android, because unlike IOS, i keep my apps in app drawers, and not infinitely cluttered homescreens - 09-17-2012, 04:48 PM
Thread Author #24
Yeah I'm not sure how I feel about it. Got a get used to it.
- 09-17-2012, 04:51 PM #25
You do realize that just because there is an average it doesn't mean you are going to get the same usage everyday? The average is based off of numerous days of usage and it get the "average" of all of them.
Mine is at 17 hrs and 20 mins now, just because there was a while I didn't use my phone that much, keep in mind that I have a razr maxx also.
Sent from my RAZR MAXXIMUS
Reply
