1. cgardnervt's Avatar
    Hey guys!
    I am having an issue. I have GO SMS Pro on my S3 and I have been using it for months. However I have found that I can SEND an MMS but I can not have an MMS sent to me....Any ideas from the S3 masses?
    I have the ATT version of the S3. Yes I am on the data network and not WiFi. I cant even see how I could download them. I just get nothing. Sorta frustrated with it. I did some research and no anvil! SO here I am!
    Thanks for the help guys.
    09-14-2012 09:04 AM
  2. xlDeMoNiClx's Avatar
    That's weird since i use it on my 3VO and MMS works fine. Takes a minute to receive the pic and slows the app down to a halt but it works.
    Maybe it's a bug in the S3 version of the app?
    Sent from my HTC EVO 3D X515a using Android Central Forums
    09-14-2012 09:55 AM
  3. Sykotc's Avatar
    I'm on Sprint's GSIII & I use GoSmsPro daily, with no issues receiving MMS. The one issue I have is when sending a pic through GoSMS it makes it blurry and unusable on the recipient's end.
    09-14-2012 09:59 AM
  4. cgardnervt's Avatar
    I feel like its a setting issue. APNs all work fine.
    09-14-2012 11:01 AM
  5. graffia274's Avatar
    It is a settings issue, I had the same problem but tweaked the MMS settings and it started working.
    cgardnervt likes this.
    09-14-2012 03:14 PM
  6. cgardnervt's Avatar
    What did you tweak?
    Thanks
    09-14-2012 03:41 PM
  7. graffia274's Avatar
    Is "Preserve image resolution" unchecked? If it is, then check that box. I'm not positive, but I think that's what I did.
    09-14-2012 04:18 PM
  8. cgardnervt's Avatar
    Thanks I will try that out!
    09-14-2012 04:24 PM
  9. funkylogik's Avatar
    i also dont recieve them. APN are fine. the pic just doesnt download. ill try tinkering with that setting mate cheers
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or crazy) guess
    09-14-2012 06:17 PM
  10. funkylogik's Avatar
    wow thanks so much Graff. i un-checked it and the pics of my brothers new dog appeared. nice one man i owe you x
    09-14-2012 06:21 PM
  11. cgardnervt's Avatar
    I did not fix anything for me.
    09-15-2012 07:17 AM
  12. cgardnervt's Avatar
    /bump!
    Am I missing some other settings for me to get MMS?
    09-16-2012 11:14 AM
  13. funkylogik's Avatar
    double check your APN mate.
    is it a combined internet/mms APN or two separate ones?
    09-16-2012 12:13 PM
  1. S3 need help with connecting to PC and Go SMS pro
    By boflexx in forum T-Mobile Galaxy S III
    Last Post: 08-03-2012, 08:53 PM
  2. Google Voice and Go SMS Pro - Use only the GV number
    By TheEFAF in forum T-Mobile Galaxy S II
    Last Post: 06-30-2012, 08:40 PM
  3. widget locker and go sms pro question
    By hybridboy695 in forum Android Apps
    Last Post: 11-12-2011, 04:00 PM
  4. problem with go sms pro on incred 2
    By juztfurfun in forum Verizon Droid Incredible 2
    Last Post: 10-21-2011, 09:01 AM
  5. EVO 3D and GO SMS Pro issues
    By jorgesicas#AC in forum HTC EVO 3D
    Last Post: 06-26-2011, 10:09 AM
