- 01-22-2013, 12:31 AM #26
Re: Galaxy S3 Battery life
I had poor battery life after the JB update. So I cleared my device cache and reset my phone. I didn't want to set up all my stuff again but took a chance since this worked for me before. And it worked again. Now i have really good battery life and can get through a day 12-14 hrs on medium use. I have everything but BT on all the time and screen brightness on Auto.
Sent from my SCH-I535 using Android Central Forums - 01-22-2013, 03:47 AM #27
- 01-22-2013, 03:09 PM #28
- 01-22-2013, 03:33 PM #29
Wait, you're saying you've still got 78% of your battery left after 24 hours? You've got nothing to worry about. Be happy. Understand these phones are never really asleep. You can worry about trying to make your battery last for days, or you can actually USE the phone for what it's designed for and charge it up once in a while. If all you want is something to send and receive SMS's on, you can buy a dumb phone and have the battery last for a week. And save a whole lot of money on the phone and a data plan.
I've never understood what the big deal is with plugging your phone in every night to recharge the battery. Or even for an hour or two during the day if needed.
As nolittledroid suggests, using wifi is more efficient than using 3G/4G, as long as you have a fairly strong wifi signal.PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
If I've helped you, please press the Thanks button.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 01-25-2013, 01:06 PM #30
I can only tell you what I have done that has helped. I turned off "automatic" for screen brightness and have it set the lowest light I can comfortably deal with. My area only has 3G, so I have it set to not look for 4G. My previous phone used a lot of battery looking for wifi (which I never use because I rarely have access and do have unlimited data), but I'm not so sure about the SG3...I have tried it both ways and don't see much difference. One thing that I did discover was sucking a lot of juice was the annoying Google+ app. After disabling it (I would uninstall if I could) that helped quite a bit. I try to keep wallpaper for home and lock screens dark and do not use live wallpaper. I was told Juice Defender would help, but it seemed to use more than it saved so I don't use it. I typically charge it every night, and go to bed at over 40%. That usually means 1 or 2 calls, checking a social site or 2, maybe poking around Google Play or checking email, and then anywhere from 50 to 200 texts in a day. Is that light use? I'm not sure, but I usually start the evening at around 85%, so compared to previous phones, I am pretty happy so far. I think for the most part, it depends on what you expect, and what your previous experience is.
- 04-07-2013, 09:05 PM #31
- 04-07-2013, 11:13 PM #32
Lord Android, is there a questions associated with this?
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 04-08-2013, 12:41 AM #33
- 04-08-2013, 08:12 AM #34
Well, mostly it's about people complaining about their battery life, and looking for help to make it better.
Samsung Galaxy S Battery Life Help
By Plinkfoyd in forum General Help and How ToReplies: 3Last Post: 05-17-2013, 08:05 PM -
Galaxy S3 Battery ?
By cea1203 in forum Verizon Galaxy S3Replies: 7Last Post: 03-06-2013, 10:18 AM -
galaxy nexus battery life
By austinmueller99 in forum Verizon Galaxy NexusReplies: 18Last Post: 02-10-2012, 06:30 PM -
AT&T Galaxy Nexus - Battery Life?
By scottder in forum Google / Samsung Galaxy NexusReplies: 3Last Post: 12-19-2011, 09:07 PM -
Galaxy Tab Battery Life - Pretty Darn Good
By zmetl in forum Samsung Galaxy TabReplies: 0Last Post: 11-07-2010, 04:36 PM
Reply
