Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Like Tree2Likes
    Default Galaxy S3 Battery life
    Hi there
    I am one of those new users who have switched from iPhone to Android.
    I heard that the Galaxy S3 battery life was suppose to be great i.e last a whole day with medium to hard use.
    However, when i purchased mine last week I found that my battery life is rather poor. I had 100% at 9am and now 2:00 my charge is close to 40%.
    I do not have any apps running the background and i cleared my ram. I am running on Power Save mode for the whole day, sync is on, wifi is off, 4G is on, GPS on and may brightness is 1/10th of its max capability
    i do get the Com.google.process.gapps error, im not sure if that does anything to the battery life.
    Is there any recommended apps or anything I can do maximize my battery power?
    Would it be helpful to upgrade my battery?
    Any help you be greatly appreciated.
  2. #2
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Default Re: Galaxy S3 Battery life
    GPS and/or a weak 4g sgnal will eat the battery mate but id also research the gapps (google app package) error even though it probably isnt causing battery drain.
    also disable google maps if you dont use it much
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or crazy) guess
    GT-I9300, UK
    Quote Originally Posted by funkylogik View Post
    I did some research about the error and it seems to be an issue with syncing --> gmail --> internet sync off... at least that seems to do the trick
    i turned off GPS and ill see how it goes.
  4. #4
    Dude, don't turn off GPS, you don't need to, and please don't disable Google Maps! GPS will only drain battery when being used by GPS apps, not when those apps aren't open. You can see the flashing target in the notification bar, that says GPS is trying to acquire a location. The only other time GPS will be used is for certain sites that check your location like Google's main search page, but I turn off the location under Google's search so it doesn't check my GPS location each time I simply want to do a quick search. Outside of that GPS is not a problem at all.
    Sounds to me that error you were getting having to do with mail sync is the culprit. I don't have any syncing email accounts either on my phone, I go into my email app (K-9) and hit check when I want to check mail and it does all three of my accounts. For business use one would need the constant sync but I don't since it's just my personal device.
    I typically drain 1% every 2 - 2.5 hours just standing by. I've found the thing that drains the battery the most is web browsing, wow what a drainer it is! But, it still lasts me a whole day even posting a ton on here. Even watching movies drains battery less. I was on a flight recently and watched about 4 hours of movies and I think I was only at like 65% battery from 100% or something around there. I was stunned as I expected more drain.
    Funky is right though... 4G will drain the battery on any device. Sometimes it says you have full bars but something with the signal won't be right and it will cause the battery to drain. As an IT Tech for a living I've seen this issue with 4G Blackberry's for a long time now.
    Rev.
    Galaxy S3
    Ubuntu Linux 10.04
    IT Tech
    Thanked by:
    John-Smith likes this.
  5. #5
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Quote Originally Posted by Rev2010 View Post
    Rev.
    i just disable maps coz im sick of it starting itself when i rarely use it lol.
    are you SURE! GPS wont always be lookin for a satellite when youre indoors etc and wasting battery mate? if youre absolutely sure, ill leave mine on to help in a theft/loss situation
    p.s, as rev says, if youre keeping sync off then keep mobile data switched off unless you need it or theres an app that lets you use 3g instead of 4g if your 3 is stronger, think its named "phone signal data" or something
    GT-I9300, UK
    Thanked by:
  6. #6
    tech_fan's Avatar
    Posts
    Global Posts
    71 Global Posts
    Quote Originally Posted by Hellfire7 View Post
    Hi there
    I came from the Iphone 4 and actually almost returned the S3 because of the battery. Here is what I did....I downloaded Juice Defender free version and tried it. It gave me 50% better battery life. I then decided to try the Juice Defender Ultimate. That increased my battery life by 200% consistently each day. I figured spending $5 for an app would be better than returning the unit.
    I also ordered the Hyperion 4200 from Amazon. That would give you excellent battery life BUT you are restricted to their one and only case.
    Juice Defender Ultimate is a great solution. There are limitations. For example when I stream Pandora, I have to switch it off. If I am dialing a phone number sometimes its sluggish in dialing extensions and might need to be turned off. There are ways to customize the software and I am sure there is a feature so that I do not have to disable it, I just do not need to customize it as of yet. By the way, I select Balanced for my profile on Juice Defender. You can select Aggressive if you really want to conserve battery power.
    Now the unit allows me to get through my day with about 20-45% left at the end of night. The phone is taken off the charger at 6 a.m. and goes back on the charger at 8 p.m..
    ---------- Post Merged at 06:43 PM ---------- Previous Post was at 06:40 PM ----------
    Also if the keyboard starts to drive you nuts, I would switch to Swiftkey 3. The more you use that keyboard, the more it customizes it for you and you will wind up liking the predictive wording again.
    Thanked by:
    Rev.
    so you think if i switch to k-9 as my email client and disable my default email address my battery would be better?
    ---------- Post Merged at 11:38 PM ---------- Previous Post was at 11:37 PM ----------
    Quote Originally Posted by tech_fan View Post
    I just got the Juice Defender Ultimate and ill see how it works. I was a customize button there should you ever need to change your settings.
    I am considering the Hyperion 4200 but its looks massive and the Galaxy loses its nice slim profile. Whats your opinion on it in terms of bulk?
    Thank you everyone for your help! if there is anything else please keep posting.
  8. #8
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    if it was me, id rather just carry a spare battery in my back pocket mate
    GT-I9300, UK
    are there any recommended brands i.e Hyperion? I do realized that if i do with cheap ones the battery will die in no time.
  10. #10
    tech_fan's Avatar
    Posts
    Global Posts
    71 Global Posts
    If I was going to do an extended battery, I would go with the Hyperion 4200. The reviews on Amazon are all positive and they rave about the battery life. For me, I bought the phone for its slim design and features and I hate to admit it but, I also bought it for the flip case that is made by Samsung. I bought a Spigen for the pocket that is on the inside but it did not look as good nor did it fit as well.
  11. Thread Author  Thread Author    #11
    The only thing that is keeping me away from the hyperion 4200 is its size. i've seen videos etc.. but its still hard to judge its size without holding it in person.
    In the future I am considering to get an induction charger which the hyperion 4200 does not support.
  12. #12
    tech_fan's Avatar
    Posts
    Global Posts
    71 Global Posts
    Yeah that is one thing that turned me off of the extended batteries. Long time ago, I bought a DROID X and the battery life was not good. Verizon sold a sightly larger battery which was made by Motorola that I used. I did not have to swap cases or compromise thickness.
    Samsung makes a battery for the S3. I believe it is the 2300 which will give you an extra 10% battery life. They battery is only slightly larger. I also heard that Mophie is coming out with an extended battery that I believe just plugs into the bottom of the phone. I think that unit will retail for about $120 if memory serves me correctly. Hopefully Juice Defender Ultimate will work out for you.
    Thanked by:
  13. #13
    I found a Video on You Tube, after that I had approx. 6 till 7 hours more energy and my Samsung was faster!!
    Go to You Tube and searching:
    Samsung Galaxy S3 - Save lots of battery in 5 steps
  14. #14
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    boops!
    GT-I9300, UK
  15. #15
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Quote Originally Posted by euradan View Post
    thats an old one but a good one bro. i keep the other two scalings at .5 though for prettyness but they can be set to zero too
    Unbranded Global s3, Official JB, Paisley, Scotland, Western Europe :beer:
    GT-I9300, UK
  16. #16
    If just buying and loading Juice Defender Ultimate would increase my battery life by 200%... I think I'd pay a lot more than they're asking, and I think Samsung would have some of that juice built in. I ran the free version for a few weeks and saw marginal gains, at best. I did notice I ended up having to turn it off too many times to make things work right. 8 to 12 hours of "normal" usages seems to be what most people tend to get, juiced or otherwise. My old Moto flip would last almost a week, but then... about all you did was make and take calls now and then. I wish batteries lasted for weeks but have to accept they don't. Keep a charger handy, a spare battery if you need one and wait for the next technological breakthrough in batteries to come.
    Blessed are they who can laugh at themselves, for they shall never cease to be amused.
    AOKP 4.2.2 Milestone 1
  17. #17
    What does "Samsung Galaxy S3 - Save lots of battery in 5 steps" do!? like literally what does it do if you set it high, or low?
    Here is mine
    My battery life is good, I guess, I wouldnt say excellent until I know for sure that it is. Here how I used my phone yesterday.
    I unplugged my phone from charger at 7:30am
    Pandora on the background for like 25 mins
    Played hill climb racer for another 20 mins
    the usual facebook 10-15 mins.
    Watch the hangover II(1:40) with headphones, and my phone died right after that. (around 12:30pm)
    brightness about 27-30%
    Is that a good battery cycle? I mean 3 hours of usage seems a bit too low, but then again watching a HD movie on that big of a screen should drain the battery fast.
    What do you guys think?
  18. #18
    Here are my Batt Stats: 25%-30% screen dimmed a combination of WiFi and LTE throughout the day, smart stay, and screen time out 15secs, emails and text moderately including voice calls screen time 3hrs 20mins
    Sent from my SCH-I535 using Tapatalk 2
    Attached Thumbnails Attached Thumbnails Galaxy S3 Battery life-uploadfromtaptalk1353114665387.jpg
    Galaxy S4 ATT
    Galaxy S3 VZW
    Nexus 7
    Xoom LTE VZW
  19. #19
    Hi , if your battery problem still exists, pl install the update which we got in india day on 25th Nov. Build No JRO03C.I9300XXDLK1. this fixed all the battery issues, the over night discharging vanished. i full charged the fone at night around 11PM, and now it is 930PM the next day. i still have 33% battery reaining. voice calls - 1hr50 mins, screen on 2h36m, cell stand by 14h 3 m, device idle 11h 26 m, etc etc.
    i am really happy now with the performance of the battery and i am not installing any app for battery maximization etc.
  20. #20
    I'm on verizon and there isn't a "disable" available for maps, just force stop and I assume it starts itself again on its on.
    - - - Updated - - -
  21. #21
    Default
    Quote Originally Posted by Rakesh Sharma View Post
    Where do u put thr code in at? Still trying to figure this thing out. Battery dies too quick for me to play my music at work. Any help is greatly appreciated. Thx.
  22. #22
    your battery is just fine.. you just turn off the 4G and the GPS.. they consume so much of energy.. turn them on when you need them! then your phone will be on twice longer !!
  23. #23
    Hi,
    I just bought the samsung galaxy 3 and like some others I was a little disappointed of the battery life. This is what I did:
    - wifi is turned off,
    -gps is turned off
    - screen rotation is turned off
    - bluetooth is turned off
    - mobile data is turned off
    - blocking mode is rurned off
    - power saving is turned on
    - all share cast is turned off
    - multi window is turned off
    - screen brightness is +-10%
    no applications are runing, Ram is cleared
    And best of all, my samsung is most of the time in standby mode. And if it's turned on it's for sending sms
    After 24 hours my phone is 78%
    If I would have used internet, wifi or even an app, I would have thought it normal, but nothing is running.
    What's the maximum battery live for samsung s3?
  24. #24
    Switch to WiFi and turn off mobile data where you can! Will definitely help a little.
    Sent from my SCH-I535 using Android Central Forums
    Sent from my S3
  25. #25
    Also, make sure you turn off haptic feedback and the keyboard vibration and noise!
    Sent from my S3
  1. Samsung Galaxy S Battery Life Help
    By Plinkfoyd in forum General Help and How To
    Last Post: 05-17-2013, 08:05 PM
  2. Galaxy S3 Battery ?
    By cea1203 in forum Verizon Galaxy S3
    Last Post: 03-06-2013, 10:18 AM
  3. galaxy nexus battery life
    By austinmueller99 in forum Verizon Galaxy Nexus
    Last Post: 02-10-2012, 06:30 PM
  4. AT&T Galaxy Nexus - Battery Life?
    By scottder in forum Google / Samsung Galaxy Nexus
    Last Post: 12-19-2011, 09:07 PM
  5. Galaxy Tab Battery Life - Pretty Darn Good
    By zmetl in forum Samsung Galaxy Tab
    Last Post: 11-07-2010, 04:36 PM
