Results 1 to 15 of 15
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    ROM
    touchejiz
    Default "miscellanious" in settings>storage?
    what is it for?
    and can it be just moved to external sd to free space?
    thanx
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or crazy) guess
    GT-I9300, UK
  2. Thread Author  Thread Author    #2
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    ROM
    touchejiz
    Default Re: "miscellanious" in settings>storage?
    anybody? its using well over a quarter of my internal memory lol
    GT-I9300, UK
  3. #3
    you can click on any of those and it will tell you what exactly it is spending the memory on
    ---------- Post Merged at 10:41 PM ---------- Previous Post was at 10:39 PM ----------
    most of my memory on the misc files are game files and thumbnails
    Thanked by:
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    ROM
    touchejiz
    Quote Originally Posted by sancho8484 View Post
    thanks, i know (i deleted a few useless ones) but can they just be moved to external sd without causing problems mate?
    GT-I9300, UK
  5. #5
    That one is easy. "Miscellaneous" files are usually media files that you've sideloaded or come from an app that doesn't/can't tag it into the appropriate category. For example I use beyondpod for podcasts, and all of the podcasts I download end up showing up in miscellaneous. That is (usually) the same thing with movies or music that doesn't come from Google Play.
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    ROM
    touchejiz
    Quote Originally Posted by wunderbar View Post
    ahh so in my case its probably sideloaded apps
    thanks man
    GT-I9300, UK
  7. #7
    Reciprocal's Avatar
    Posts
    Global Posts
    58 Global Posts
    ROM
    CM10 Stable Build
    i also noticed when I was flashing Roms a lot. there was always some left over files from apps that didnt get properly added to the storage categories. so even when i went in and looked at the Misc category, it wouldnt show what was taking up 9GB of data. I ended up going into clockworkmod recovery and (after backing, of course) formatted the internal storage. that pretty much cleared up everything.
  8. #8
    So, wifes phone has 14 gigs of miscellaneous whatever. I need to transfer them to the sd card or know what is going on. Please help with at least accessing those files to know what it is Im looking at
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    ROM
    touchejiz
    Use ES File Explorer man
    quadcore 1gb GS3, Neat Rom by Salesale. Paisley, Scotland, Western Europe :beer:
    GT-I9300, UK
  10. Thread Author  Thread Author    #10
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    ROM
    touchejiz
    GT-I9300, UK
  11. #11
    Dog5000's Avatar
    Posts
    Global Posts
    365 Global Posts
    Good post. I became curious as to exactly where to find a directory called "Miscellaneous files" or "System Memory". Didn't find anything called "Miscellaneous" when searching via Root Explorer. So with the hints from posts in this thread I started to look for individual folders that show up in the "System memory" heading underneath the Miscellaneous files setting. My biggest "offender" is a folder called "syncr" at 7.44GB. I then used the My Files app (could certainly use ES File Explorer), and navigated to sdcard0/syncr. Inside this directory is all of my music and related apps that iSyncr helped copy over from iTunes. Next I deleted the syncr folder from within the My Files app. Went back to "System memory" and sure enough the "syncr" folder is gone. This may be a space management process that non-rooted or rooted users could use safely - of course you have to decide what you think is safe to delete on your phone - not me Lastly, in Linux terms perhaps the "System memory" may just be a symbolic link like mount point to various random files/folders on the phone. Perhaps the developers in the forums can help confirm or correct me on this last point.
    5.42 GB available space on my Note 2 - How about you?
    Thanked by:
  12. #12
    Is your music also stored somewhere else on the phone?
    PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
    If I've helped you, please press the Thanks button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
  13. #13
    Dog5000's Avatar
    Posts
    Global Posts
    365 Global Posts
    Quote Originally Posted by meyerweb View Post
    Yes it is. Music lives in the sdcard0/Music directory. Believe I had music scattered about via Kies and iSyncr synchs.
  14. #14
    Dog5000's Avatar
    Posts
    Global Posts
    365 Global Posts
    Quote Originally Posted by Dog5000 View Post
    I'll add that my music was a bit of a mess due to trying out various synching tools and music apps. Had multiple copies of a playlist, etc. So, this will give me a good reason to clean everything up and reduce storage space at the same time.
  15. Thread Author  Thread Author    #15
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    ROM
    touchejiz
    After a reset, my misc' shrunk to almost gone.
    Cheers for the tip Dog
    Mine seemed to be full of non-playstore apps which ive quit trusting anyway
    GT-I9300, UK
  1. activation option in settings.
    By m3lover1 in forum Motorola Xoom
    Last Post: 02-26-2011, 11:37 AM
  2. turning off back round sync in settings??
    By phillyeagle30 in forum HTC EVO 4G
    Last Post: 09-26-2010, 09:41 AM
  3. Replies: 9
    Last Post: 09-21-2010, 03:21 PM
  4. What is "Accessibility" in Settings?
    By AnAm85 in forum myTouch 3G Slide
    Last Post: 08-18-2010, 05:16 PM
  5. accessibiliyt in settings
    By raven71#ac in forum AT&T Captivate
    Last Post: 08-06-2010, 02:45 PM
