Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Like Tree11Likes
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Carrier
    touchejiz
    Default HELP! ive broke my phone!
    ok ok i sideloaded a cracked app from a free source to test the battery drain so please no "told ya so" posts
    now my screen will only stay on from between a split second to 2seconds.
    i THINK i managed to uninstall the app but problem persists.
    whats my next option before *cringe* factory reset?
    (unrootod s3, lockscreen works but only opens home for a flash)
    thanks in advance
  2. Thread Author  Thread Author    #2
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Carrier
    touchejiz
    Default Re: HELP! ive broke my phone!
    i can understand a lack of sympathy but was testing the apps battery usage for a friend as praystore refund policy doesnt really allow for that and if i liked it, i WOULD have bought it!
  3. #3
    Quite a pickle you're in, friend! Probably a dumb question, but did you try rebooting your phone?
    Sent from my HTC One X
    funkylogik likes this.
  4. #4
    You could try a soft reset first. Just hold the power button in until the phone reboots. Good luck!
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Carrier
    touchejiz
    thanks. did both. cant even seem to get into Safe Mode can still recieve text. really dont wana factury reset coz havent backed app settings to my new sd and my girl formatted the old one lol.... maybe a reset would be ok... ill do a Kies backup
    any more help would be worth a bj lol
    ---------- Post Merged at 09:13 PM ---------- Previous Post was at 09:08 PM ----------
    Quote Originally Posted by ansextra View Post
    soft reset as you described it kept the screen on for much longer mate ....
  6. #6
    Ricky Babalu's Avatar
    BEACH BUM
    Posts
    Carrier
    Stock : Rooted, Unlocked
    Oh boy! Are you able to access Menu>System settings>Security?
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Carrier
    touchejiz
    right soft reset keeps the phone on until i turn screen off then its back to square one... so what do i uninstall to fix it?
    ---------- Post Merged at 09:20 PM ---------- Previous Post was at 09:19 PM ----------
    think so mate, gota soft reset again, why? @Ricky
    wheres system settings? do u mean "securiyy and lock settings" mate? @Ricky
  8. #8
    BEACH BUM
    Posts
    Carrier
    Go there and tell me what is listed:
    Menu>System settings>Security>Device Administrators
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Carrier
    touchejiz
    yeah got device admin mate, its both my security apps (avast and android lost). just ran AVG and it says im protected?
  10. #10
    BEACH BUM
    Posts
    Carrier
    Does not seem like anything there is abnormal. I would suggest to err on the safe side and do a factory reset at this point. I know that is not what you wanted to hear, but the fact that your text is working is a major concern as "pirated apps" are known for utilizing this to extract revenue. I would do it as soon as possible.
    That is the only way you will be sure that your phone is rid of any Trojan/Malware.
  11. Thread Author  Thread Author    #11
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Carrier
    touchejiz
    think ur right mate. im actualy using the phone now. even Zoner found no viruses. at least i should be able to back up my launcher and go sms settings 1st.
    thanks mate
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
  12. Thread Author  Thread Author    #12
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Carrier
    touchejiz
    ps my txts are part of a pre-pay package which has no credit in it so that doesnt worry me but dont wanna soft reset the phone every time i use it lol. ill do a kies back up n then bite the bullet... big lesson learned lol its the 1st time ive been bitten by pirated app
    ---------- Post Merged at 09:57 PM ---------- Previous Post was at 09:48 PM ----------
    will the s3 auto download my installed apps after reset? im unrooted and usin mybackup pro to save em online as it doesnt have ext' sd option but i doubt itl give me enough online storage.. any suggestions mate?
  13. Thread Author  Thread Author    #13
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Carrier
    touchejiz
    omg we'r still at letter A lol.... will kies back up my apps faster?
  14. #14
    BEACH BUM
    Posts
    Carrier
    Why are you backing up your apps? They can all easily be re downloaded from the play store.
  15. #15
    Quote Originally Posted by Ricky Babalu View Post
    Unless he's got paid apps that aren't paid for.....LOL.
    sent from my bolt using tapatalk
  16. Thread Author  Thread Author    #16
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Carrier
    touchejiz
    that and just because im lazy. its cool though, Go Backup backs up to ext sd
  17. #17
    On my tbolt mybackup pro defaults to the external sd. They are in the rerware folder.
  18. Thread Author  Thread Author    #18
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Carrier
    touchejiz
    lmfao. after all that, i tried turning screen off/on before reseting and somehow its fixed itself!!!
    no part of my logical brain can understand that but my girl would call it "luck" lol thanks everyone xx
    special big-up to ma man Ricky... i owe u dude
  19. #19
    Quote Originally Posted by funkylogik View Post
    I believe the reward was a free bj
    On my Samsung galaxy s3 running android 4.0
    Because unlike ios, i keep my apps in app drawers, and not in infinite cluttered homescreens
    funkylogik and gvndeb60 like this.
  20. Thread Author  Thread Author    #20
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Carrier
    touchejiz
    lmao it may be in writing but we didnt shake on it mate
    TauSigmaNova likes this.
  21. #21
    you gotta suck it, all you have in this world are your balls and your word.
  22. #22
    minnick's Avatar
    Posts
    Global Posts
    244 Global Posts
    I think u owe the man a bj
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  23. Thread Author  Thread Author    #23
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Carrier
    touchejiz
    dammit ok.... but im not shaving 1st
  24. #24
    Tkbredx's Avatar
    Posts
    Global Posts
    2,123 Global Posts
    Carrier
    TeamSonicFreeGS3 v9.1
    Hahahaha
  25. #25
    I call seconds
  1. Help I broke my phone
    By doug61 in forum Introductions
    Last Post: 08-17-2012, 09:12 AM
  2. Help! Motorola Media Link broke my phone?
    By Puzzlegal in forum Sprint Photon
    Last Post: 01-29-2012, 06:58 PM
  3. Im a noob and broke my phone. Please help.
    By ompapamowmow in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 11-21-2011, 09:29 AM
  4. Help me fix my phone
    By fstbusa in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 01-08-2011, 12:28 PM
  5. Help with Rooting my phone please.
    By rm2092 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 12-07-2010, 09:21 AM
