Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By GSDer
  • 1 Post By GSDer
    jaekim717's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default gps slow to lock when using navigation
    hey,
    anyone else experiencing really slow locks for the gps when using navigation? it seems to lock on fine when just using google maps, but when i go to use the navigation feature, it takes forever. i will even turn on wifi, gps, and it takes at least 5 mins. i can see on the map it knows exactly where i am but i get a message on the bottom of the screen saying, 'searching for gps'. anyone know of how to fix this? do i have a problem with the hardware/gps on my phone?
    thanks,
    jae
  2. #2
    ansextra's Avatar
    Posts
    Global Posts
    1,507 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: gps slow to lock when using navigation
    Most of the time mine locks on instantly.
    jaekim717's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yeah that's what i hear from most everyone, think i have dud!!!
    jaekim717's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    so does anyone have any advise on how to resolve this issue other then trying to get it exchanged?
  5. #5
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Check out GPS Test Plus: http://market.android.com/details?id...ss.gpstestplus on the Play Store - there's a free version that may help you out. If I remember correctly, there's also a way to delete the current almanac (database of GPS satellites) and refresh it which should also help.
    The SGSIII should be better than most phones since it also uses the Russian GPS satellites.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    Rev2010 likes this.
  6. #6
    Rev2010's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Take GSDer's advice, it downloads GPS Assistance data which supposedly speeds up the GPS lock time since it looks at additional satellites it normally isn't aware of, or so I've read. I mainly use it to calibrate the compass but it works very well and is free. GPS lock on works perfect for me, but I only use Google Maps and use it's own Navigation so everything has worked fine.
    Rev.
  7. #7
    jenbot2009's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default you gotta be on a govt watchlist with that kinda phone knowledge!!!lol
    any chance you ca walk me through getting new data base on my note 2?
  8. #8
    meyerweb's Avatar
    Posts
    Global Posts
    10,319 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: you gotta be on a govt watchlist with that kinda phone knowledge!!!lol
    If you're in a car, it will probably take longer to lock than if you're outdoors, because the metal roof blocks some of the signal from the satellites. But if it really locks faster, in the same location, on maps than in nav, open maps first, then once it locks in switch to nav.
  9. #9
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    jenbot2009,
    Once you install the app that I listed above (or the free version of the same app), start the app, access the Settings, thenClick image for larger version.
ID:	66440Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    meyerweb likes this.
  1. GPS really slow to lock in
    By sbudaj in forum Droid Bionic
    Last Post: 09-06-2012, 02:00 PM
  2. Note switches from Wifi to 4g when using apps
    By bluerose5 in forum Samsung Galaxy Note
    Last Post: 06-27-2012, 05:16 PM
  3. Screen problem when using navigation
    By APeX3181 in forum Droid Bionic
    Last Post: 09-15-2011, 03:40 PM
  4. GPS fails to lock
    By RedneckBB in forum AT&T Inspire 4G
    Last Post: 03-29-2011, 06:17 AM
  5. Evo thinks it's connected to PC when using charger
    By larrysir in forum HTC EVO 4G
    Last Post: 08-26-2010, 06:46 PM
